flowcode usb serial and ecio unknown device
- misoct
- Has thanked: 8 times
- Been thanked: 17 times
>>ECiO-40p-40pin module device driver software installed successfully installed
>>flowcode usb serial unknown device i mean that the device manager cannot recognize on the flowcode usb serial
after generate driver file: mchpcdc saved ..
compile to chip
this is the result of compiling :-
File name: C:\Users\KHALID\Desktop\RFID PROJECT\rfiduid.c
Generated by: Flowcode v4.3.7.63
Date: Monday, December 13, 2010 12:02:48
Licence: Professional
Registered to: Dr.THAROWAT
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic18.flowcode.exe -v -t PIC18F4455 "rfiduid.c"
BoostC Optimizing C Compiler Version 6.95 (for PIC18 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2009 Pavel Baranov
Copyright(C) 2004-2009 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC18 max code size:Unlimited, max RAM banks:Unlimited
rfiduid.c
Starting preprocessor: C:\PROGRA~1\MATRIX~1\FLOWCO~1\BoostC\pp.exe "C:\Users\KHALID\Desktop\RFID PROJECT\rfiduid.c" -i C:\PROGRA~1\MATRIX~1\FLOWCO~1\BoostC\include -d _PIC18F4455 -la -c2 -o "C:\Users\KHALID\Desktop\RFID PROJECT\rfiduid.pp" -v -d _BOOSTC -d _PIC18
rfiduid.c success
success
Return code = 0
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostlink.pic.exe -rb 0x800 -ld "C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\lib" libc.pic18.lib flowcode.pic18.lib rand.pic18.lib float.pic18.lib "rfiduid.obj" -t PIC18F4455 -d "C:\Users\KHALID\Desktop\RFID PROJECT" -p "rfiduid"
BoostLink Optimizing Linker Version 6.95
Warning unreferenced functions removed:
FCI_FLOAT_TO_STRING in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCI_NUMBER_TO_HEX in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCI_STRING_TO_INT in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCI_STRING_TO_FLOAT in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
Wdt_Delay_S in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
isinf in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCD_RFID0_Write_RFID_Module in: C:\Users\KHALID\Desktop\RFID PROJECT\rfiduid.c
FCD_RFID0_Get_RFID_Status in: C:\Users\KHALID\Desktop\RFID PROJECT\rfiduid.c
FCD_RFID0_Get_RFID_Type_ID in: C:\Users\KHALID\Desktop\RFID PROJECT\rfiduid.c
FCD_RFID0_Store_RFID_Key in: C:\Users\KHALID\Desktop\RFID PROJECT\rfiduid.c
FCD_RFID0_Write_RFID_Buffer in: C:\Users\KHALID\Desktop\RFID PROJECT\rfiduid.c
FCD_RFID0_Read_RFID_Buffer in: C:\Users\KHALID\Desktop\RFID PROJECT\rfiduid.c
FCD_RFID0_Write_RFID_Block in: C:\Users\KHALID\Desktop\RFID PROJECT\rfiduid.c
FCD_RFID0_Read_RFID_Block in: C:\Users\KHALID\Desktop\RFID PROJECT\rfiduid.c
FCD_RFID0_Format_RFID_Value in: C:\Users\KHALID\Desktop\RFID PROJECT\rfiduid.c
FCD_RFID0_Increment_RFID_Value in: C:\Users\KHALID\Desktop\RFID PROJECT\rfiduid.c
FCD_RFID0_Decrement_RFID_Value in: C:\Users\KHALID\Desktop\RFID PROJECT\rfiduid.c
FCD_RFID0_Transfer_RFID_Value in: C:\Users\KHALID\Desktop\RFID PROJECT\rfiduid.c
FCD_LCDDisplay0_PrintASCII in: C:\Users\KHALID\Desktop\RFID PROJECT\rfiduid.c
FCD_LCDDisplay0_Command in: C:\Users\KHALID\Desktop\RFID PROJECT\rfiduid.c
FCD_LCDDisplay0_PrintString in: C:\Users\KHALID\Desktop\RFID PROJECT\rfiduid.c
FCD_LCDDisplay0_ScrollDisplay in: C:\Users\KHALID\Desktop\RFID PROJECT\rfiduid.c
FCD_LCDDisplay0_ClearLine in: C:\Users\KHALID\Desktop\RFID PROJECT\rfiduid.c
FCD_LCDDisplay0_RAM_Write in: C:\Users\KHALID\Desktop\RFID PROJECT\rfiduid.c
usb_get_state in: C:\PROGRA~1\MATRIX~1\FLOWCO~1\BoostC\include\USB\pic_usb.c
FCD_USBSerial0_SendByte in: C:\Users\KHALID\Desktop\RFID PROJECT\rfiduid.c
FCD_USBSerial0_ReadByte in: C:\Users\KHALID\Desktop\RFID PROJECT\rfiduid.c
Building CASM file
Memory Usage Report
RAM available:2048 bytes, used:703 bytes (34.4%), free:1345 bytes (65.6%),
Heap size:728 bytes, Heap max single alloc:127 bytes
ROM available:22528 bytes, used:7924 bytes (35.2%), free:14604 bytes (64.8%)
success
Return code = 0
Launching the programmer...
C:\Program Files\Matrix Multimedia\Flowcode V4\tools/ECIOprog/ECIOprog.exe -nogui "rfiduid.hex"
File loaded: rfiduid.hex
ECIO not found!
ECIO not found!
ECIO not found!
ECIO-40 version: 1.1
Ready
Sending Program...
USB Write Failed
Failed with error 997: Overlapped I/O operation is in progress.
Send Failed
Ready
Return code = 0
FINISHED
with hp laptop windows 7
32 bit
compile to chip
rfiduid.c
rfiduid.c success
success
Return code = 0
Building CASM file
Memory Usage Report
success
Return code = 0
ECIO not found!
ECIO not found!
ECIO not found!
Ready
Sending Program...
USB Write Failed
Send Failed
Ready
Return code = 0
FINISHED
32 bit
jgu1
- Has thanked: 1135 times
- Been thanked: 299 times
Re: flowcode usb serial and ecio unknown device
Hi!
Do you remember to press the resetbuttom on the Eico after compiling?
Regard
jgu1
Regard
jgu1
- misoct
hi
yes i do remember
i pressed on restart button
but i cant get it did i set the ECIO driver or not if yes why the pc connat see it and giving me flowcode usb serial unkown device !!
yes i do remember
- misoct
hey
what am doing is a project RFID system to read the tags and open electrical door automatic . in the same time of the opening door database appears in the laptop that X man entered the door ..anyway everything is done oke the project work successfully , i moved the project to the another laptop then i got this problem appears also i tried to setup it on another 3 pc's with windows xp and the same problem showed up ..
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
If you search for the forum for the "error 997", you will find that it is a driver version issue. For example, see here:
http://www.matrixmultimedia.com/mmforum ... =error+997
This should fix the problem.
- misoct
Hi steve
thank you for your advise but when I open the the linkhttp://www.matrixmultimedia.com/mmforums/viewt ... =error+997[\url]
required from me pass word and username I allready entered my passward and user name that I usually I use throughh the flowcode forum but I cannt
How can I regisit on the FAQ
thanks
thanks
- misoct
hi again steve
i meant this link http://www.matrixmultimedia.com/support ... .php?t=508
i cant access to this link required from me pass word and username I allready entered my passward and user name that I usually I use throughh the flowcode forum but I cannt
thanks
thanks
- Steve
You do not need a username/password to access our FAQ site. This is a locked site and only Matrix employees have the rights to post there. You should be able to view the topic as a guest.
- misoct
Hello davidA
http://www.matrixmultimedia.com/support ... f=22&t=510 in this link:
hey steve
i tried the most of solutions u have allready posted it beofre that it may be related with my problem but without any result
i tried to change the pc but the same problem occurred
i need to use it on my laptop with windows 7
thank you
i didnt find the tick box to disable it .actually thats the aknown deviceTo allow PPP to communicate with the USB programmer board you have to goto Control Panel -> System -> Device Manager. Then find the Matrix USB programmer under the USB section and double click it. Once inside the property page goto the power settings tab and disable the tick box saying allow windows to power down this device.
hey steve
i think its required couse u copied and pasted it from ur account as u a matrix employee so off course i couldnt be able to view it ..anywayPost by Steve » Tue Dec 14, 2010 4:19 pm
thank you
- Steve
You are correct - someone else in our organisation had moved some redundant/duplicate posts to a new area where only our staff have access. I didn't realise this, so sorry for the mis-information!misoct wrote: i think its required couse u copied and pasted it from ur account as u a matrix employee so off course i couldnt be able to view it ..anyway
On to your problem, you need to update the driver for the ECIO to the latest version. If it continues to fail, you need to reset the ECIO while the program "ECIOprog" is running (this will hold the ECIO in bootloader mode and allow it to show up in the device manager). Once this is done, you can locate the ECIO in device manager and then turn off the power management setting.
Hopefully this will sort out the problem for you. Please let us know how you get on.
- misoct
about the problem , i already have the latest ECIO driver version ,and is didnt workout ,what i did now i went to the compatibility mode and i clicked on the tick box and change it to windows vista .
well now the flowcode anown device disappeared from device manager but still have the problem .. as i show u in the image ..and the another problem usb read write failed
any ideas :S :S
- misoct
no there is no tick box for that and after i restart the pc the flowcode usb serial unknown device again i really confused about this problem
- DavidA
- Has thanked: 58 times
- Been thanked: 258 times
Hello misoct,
The way to be able to view the power management section of the ECIO driver would be to load up the ECIO prog and then get the program to hold your ECIO in programming mode by connecting to the device, then go to device manager and the ECIO should be visible near the top as a custom USB device, you can then enter the properties for this and one of the tabs should be "Power management" under this tab you should be able to untick the "Allow the computer to turn off this device to save power".
- misoct
hello matrix team
thank u steve and david i appreciate that very much
well i just fixed the device manager problem but the ECIO programme seems that its a temporary solution couse after i closed it , the flowcode usb serial unkown device appears again... btw before i do ur instructions i did something wrong i thought that could help i unistall flowcode and reinstall it again in that operation i did the project file not able to open :S:s i thought that could help to
its giving me error message called unexpected file format i changed it name of it couse i have it on external harddiskand i tried to open it again to compile it but the same problem unexpected file format ..here is the file if that could help
- misoct
here is it
- rfiduid2.fcf
- unexpected file format
- (11.5 KiB) Downloaded 234 times
- misoct
helloo\
i reinstall it again and now i can open it ..
for usb serial i have to genarate driver file but properties are not opening like i used to do
When reprogramming an ECIO that is running a USB component you may have to hold the rest button for a second or two when resetting to send a new program. This is simply to let the USB component time to unregister on Windows so that the ECIO USB device can take its place correctly. I have found that resetting by tapping the button can occasionally cause programming failures.
For your USB serial problem. Do you mean the properties in Flowcode for the component or do you mean the device manager properties? Can you explain further.
- misoct
hi
i did what u guys told me to do and i pressed the botton that and the flowcode usb device temporary disappered and i i cheked ont he ticked box of manager power
but its still flashing .i tryied to compile anyway, compiling succceed the led stopped flashing and still lighing ,but its supposed to ask me to reset the ECIO so i compiled it again the seconed time required to reset the ecio after reset it the flowcode usb serial unknown device come back again :S and flashing too ....
if u not get the whole image i will upload the whole operation on youtube by see how to solve this out ..what i mean the tick boz doesnt solve the problem ..
about properties question forget about it . sorry, i was wrong
