Programmable RC-5 Remote Control
Sean
Has thanked: 6 times
Been thanked: 44 times
Post by Sean »
Programmable RC-5 System
Introduction
This article describes how the new Infra-Red RC-5 E-block (EB-060) can be used with Flowcode to develop a remote control device with the ability to learn codes from other handsets.
The RC-5 E-block contains the hardware required to transmit and receive RC-5 encoded infrared signals.
In this application the transmit channel is used to transmit individual codes allocated to each of the numeric keys on a keypad. The receive channel can be used to allow individual keys to 'learn' new messages (codes) from existing, compatible, equipment handsets.
Component
The example program attached to this article uses a Flowcode Custom Component C file (also supplied) to control the EB-060 hardware.
The code contains definitions to allow this application to run on a PIC16F877A with a 19.6608MHz crystal.
ProgRC5_1.fcf
(20.44 KiB) Downloaded 1492 times
PIC_Custom.c
(12.97 KiB) Downloaded 1174 times
A fully integrated Flowcode RC-5 component will be available in the near future.
Custom code
To allow Flowcode to access the macros in the custom component, the attached PIC_custom.c file must be saved into the Components folder of the Flowcode installation. There will already be a file named PIC_custom.c in the folder, which should be renamed or moved before copying the new file into the folder.
Hardware
The EB-060 should be connected to Port B and configured as follows:
A wire link in the J9 sockets between pins 0 and 6.
The input selector jumper on J6.
The J8 jumper in the OFF position.
The J2 jumper in the 5V position.
The LCD E-Block (if used) should be connected to Port C
The Keypad E-Block should be connected to Port D
Program
The example program accompanying this article uses a keypad and (optional) LCD E-block to represent a traditional remote handset arrangement.
A previous article "RC5 remote control" explained the basics of the RC-5 protocol, which will not be covered in this article.
Default settings
On power-up the keys default to the typical values used for a main television (address = 0; command = key value). Pressing any of the numeric keys will cause the corresponding message to be transmitted.
Transmit mode
The example program handles each key press individually so the toggle bit changes state as each message is transmitted. The program can be modified to allow key presses to auto-repeat (volume control), transmitting repeated messages, with a constant toggle bit value, while a key is being pressed.
Learning mode
The program allows codes from existing, RC-5 compatible handsets to be detected and allocated to individual keys on an EB-014 keypad E-block. Codes for multiple types of equipment (different address values) can be acquired as long as they are all RC-5 compatible. The keys can then be used to control the transmission of each message (the program can be easily modified to use alternative input devices, or internal microcontroller events, to transmit each message).
The program uses the # key to toggle between 'Transmit' and 'Learn' mode. To prevent accidental re-programming, when the # key is used to enter programming mode, it must be followed by the * key. The # key can be used at any time to return to transmit mode.
When in 'Learn' mode, press the key to be re-programmed. Confirmation of the selected key will appear on the LCD (if it is being use).
Point a handset at the receiver on the RC-5 E-block and press the handset button that you want the system to learn. If the message is detected correctly, the values are assigned to the selected key and the system returns to transmit mode.
Further development
The system does not support auto-repeated transmission of messages while a key is held down. This feature may be required for functions like volume control. The program can be modified to continually transmit a message, at the RC-5 repeat rate (8 messages per second), with the toggle bit set at the same value for each transmission, while a button is being pressed.
Codes taught to the system are stored in RAM and are only retained while power is applied. The program can be modified to store alternative codes in EEPROM, and to search for them on power-up, so they can be retained indefinitely.
The program can be modified to accept signals from additional or alternative input devices to control system setup and message transmission.
Sparkoids
Has thanked: 30 times
Been thanked: 19 times
Re: Programmable RC-5 Remote Control
Post by Sparkoids »
Hi Sean,
Another adaptation of RC5 is the Philips extension that is also used by Sky TV remote controls amongst others.
http://www.arduino.cc/cgi-bin/yabb2/YaB ... 1231706417
Can your code be modified to run these remotes as well?
Thanks for this stuff anyway!
James :-}
Thanks Sean. This is a great article!
What would make it even better is if it will work for 18F4455 :P
Unfortunately I can only change defines like tmr0 to tmr0l
Since option_reg does not exist within 18F4455 not sure how to proceed any further.
would you be able to produce a PIC_Custom.c file for my target device,
Or post how It can be adapted for my device please?
Would like to get this working with my IrDA board EB012.
Thanks again.
Sean
Post by Sean »
The 877 OPTION_REG is used to swap signal edge causing an INT interrupt (so every edge is detected). This feature is available in the INTCON2 register of the 4455.
The timer values used in the state machine macro will depend on the clock frequency and prescaler being used with TMR0.
the timer should be set to operate in 8-bit mode with the lowest prescaler value that will allow an overflow period greater than 2222us.
When receiving pulses, the timer should be pre-loaded with an initial offset value that will cause an overflow after 2222us (the longest allowable pulse width).
The timer overflow flag is used to confirm that a count is not valid - but does not generate an interrupt.
The important detection periods are:
444us (minimum pulse width)
1332us (change from short to long pulse)
2222us (maximum pulse width)
Remember: the values read back from the timer will include the initial offset value.
Thanks for your reply Sean.
I have edited PIC_Custom.c for the 4455, but still fails to compile.
//common defines
#define MX_RC5_TIMER_PRELOAD	85			//Auto added to timer count
#define MX_RC5_TIMER_REGISTER	tmr0l			//Timer count register
#define MX_RC5_TIMER_TOUTREG	intcon
#define MX_RC5_TIMER_TOUTBIT	TMR0IF
#define MX_RC5_TIMER_ENREG		intcon
#define MX_RC5_TIMER_ENVAL		0x05			//Prescaler for timer
#define MX_RC5_INT_EDGEREG		intcon2
#define MX_RC5_INT_EDGEBIT		intedg0
#define MX_RC5_INT_PORT			portb
#define MX_RC5_INT_TRIS			trisb
#define MX_RC5_INT_PIN			0
#define MX_RC5_INT_ENREG		intcon
#define MX_RC5_INT_ENBIT		INT0IE
#define MX_RC5_INT_FLAGREG		intcon
#define MX_RC5_INT_FLAGBIT		INT0IF
#define MX_RC5_SIGNAL_INVERT	1
#define MX_RC5_UPPER_WIDTH		255				//2222us Approx - Must be over 1778us
#define MX_RC5_LOWER_WIDTH		119				//444us Approx - Must be under 889us
#define MX_RC5_CUTOFF_WIDTH		187				//1334us Approx - Must be around 1333us
#define MX_RC5_TX_TRIS			trisb
#define MX_RC5_TX_PORT			portb
#define MX_RC5_TX_PIN			7
#define MX_RC5_PWM				1
#define MX_RC5_PWM_PERIOD		33
#define MX_RC5_PWM_SCALER		5
#define MX_RC5_PWM_CHANNEL		1
All display of errors are suppressed, So maybe there are too many?
I am just getting:
Launching the compiler...
C:\Program Files (x86)\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic18.flowcode.exe -v -t PIC18F4455 "ProgRC5_1.c"
Return code = 1
Flowcode was unable to compile the flowchart's C code due to the following errors:
If your flowchart contains C code, please review this carefully. If your flowchart contains no C-code or you have thoroughly reviewed the code, contact Technical Support.
FINISHED
Would you mind looking at all my alterations please?
ProgRC5_1.c
(34.09 KiB) Downloaded 723 times
PIC_Custom.c
(12.97 KiB) Downloaded 720 times
Sean
Post by Sean »
Compilation succeeds if intedg0 is changed to INTEDG0.
I am not able to do any hardware testing at the moment.
If it's any help, the original MIAC RC5 article program contains the same basic receiver program (written in Flowcode) and compiled for the 18F4455. Timing and timer configuration details might be useful and are based on a 48MHz clock.
Note: The signal is inverted in the MIAC application, and connected to INT2, so the INT details should not be used for a non-MIAC application.
Thanks Sean.
The unusual thing is after the suggested change, errors now show, so does not compile like your flowchart does.
I got:
ProgRC5_1 for 18F4455.c
Starting preprocessor: C:\PROGRA~2\MATRIX~1\FLOWCO~1\BoostC\pp.exe "D:\Flowcode V4 Install and  Examples and Drivers\ProgRC5_1 for 18F4455.c" -i C:\PROGRA~2\MATRIX~1\FLOWCO~1\BoostC\include -d _PIC18F4455 -la -c2 -o "D:\Flowcode V4 Install and  Examples and Drivers\ProgRC5_1 for 18F4455.pp" -v -d _BOOSTC -d _PIC18
D:\Flowcode V4 Install and  Examples and Drivers\ProgRC5_1 for 18F4455.c(273): Illegal redefinition of symbol: MX_RC5_TIMER_REGISTER
D:\Flowcode V4 Install and  Examples and Drivers\ProgRC5_1 for 18F4455.c(276): Illegal redefinition of symbol: MX_RC5_TIMER_ENREG
D:\Flowcode V4 Install and  Examples and Drivers\ProgRC5_1 for 18F4455.c(278): Illegal redefinition of symbol: MX_RC5_INT_EDGEREG
D:\Flowcode V4 Install and  Examples and Drivers\ProgRC5_1 for 18F4455.c(279): Illegal redefinition of symbol: MX_RC5_INT_EDGEBIT
D:\Flowcode V4 Install and  Examples and Drivers\ProgRC5_1 for 18F4455.c(284): Illegal redefinition of symbol: MX_RC5_INT_ENBIT
D:\Flowcode V4 Install and  Examples and Drivers\ProgRC5_1 for 18F4455.c(286): Illegal redefinition of symbol: MX_RC5_INT_FLAGBIT
6 errors detected
Error: preprocessing error
failure
Return code = 1
FINISHED
After looking at the C file, it looks like its picking up both altered and pre-altered PIC_Custom.c,
So had a look at custom code within Flowchart and that look fine.
Custom code 18F4455.jpg (126.07 KiB) Viewed 22593 times
Also how would you know whether to use upper or lower case, as there is a mixture?
(34.21 KiB) Downloaded 731 times
Sean
Post by Sean »
If the definitions were being edited in the code customization window, Flowcode will have registered the edit and be including this version of the defines code along with the new version provided by the custom c file.
You could try deleting the contents of the custom code window. This should force Flowcode to revert to using the code supplied by the c file only.
Boost C uses lower-case text for register names and upper-case for bit definitions (this does not apply to all C compilers).
Deleted the Customised code from within flowchart, so its blank.
Still get:
C:\Program Files (x86)\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic18.flowcode.exe -v -t PIC18F4455 "ProgRC5_1 for 18F4455.c"
Return code = 1
FINISHED
I have also copied the corrected definitions from PIC_Custom.c and still the same.
Has thanked: 114 times
Been thanked: 422 times
Post by Steve »
Is this the Win7 libraries issue again??
Steve wrote:Is this the Win7 libraries issue again??
Nope as now I know what issues the libraries can cause :p
It's probably an issue with suppressing errors if too many?
Is there a way to fix that ( if that is the issue of course), or is it a boost C issue?
Was on the D drive in a folder, now moved to C drive in a folder called C:\Flowcode_Testing
Here is the full msg with just last name removed so you can see the path:
File name:     C:\Flowcode_Testing\ProgRC5_1.c
Generated by:  Flowcode v4.3.7.63
Date:          Wednesday, January 05, 2011 17:58:34
Licence:       Professional
Registered to: Martin
Return code = 1
FINISHED
ProgRC5_1.c
(34.17 KiB) Downloaded 680 times
Post by Steve »
Can you please attach (or PM) your FCF file so we can investigate further. It looks like there is an issue with the customisation of the component code somewhere.
No problem. I will post flowchart as it is just the one that Sean posted, but with target device changed to 18F445.
ProgRC5_1 for 18F4455.fcf
(20.82 KiB) Downloaded 790 times
Post by Steve »
The code for the "defines" section of the keypad component has been customized to include a load of definitions for the RC5, which might be causing some problems.
Thanks Steve. I did not know the defines to the keypad was altered to be the same as defines in the PIC_Custom.c
So all I did was copy the common defines within PIC_Custom.c and paste in the keypad defines.
Now compiles OK.
Only warning is this:
Serious Warning: Possible sw stack corruption, function 'FCD_Custom0_RC5_Initialise_States' called by more than one asynchronous thread (main/Task, interrupt, interrupt low)
Re LCD: It has to be connected to port A otherwise require patching not all default pins connections are available on port C
Program now runs, but in learn mode when press a key on the keypad e.g 1 then press remote, nothing happens. LCD keeps displaying Learn 1
I am using EB012 (as not got EB060) with no jumpers in A, B, C, 1 OR 2. got a wire connected from J6 RXIT to bit 6 (tried in bits 2 and 6 as well).
Any ideas please?
