I want work with a i2c eeprom 24FC1025
If i take as device id = 0xa0 > write i show 64 instead (160) in all v4.
regards wolfgang
i2c macro
- Dan81
- Been thanked: 60 times
Re: i2c macro
Hello Wolfgang
With "Transaction" macros , Device_ID is the "real" I2C address (7 bits) : 0x50 not the control byte 0xA0 (Write) or 0xA1(Read).
(in the code there is a "left shift" and 0xA0 becomes 0x20=64)
Daniel
Daniel
saschech@gmx.de
- Has thanked: 1 time
- Been thanked: 26 times
Re: i2c macro
Hello Daniel
ok,but what is the right input for wr or rd the 24FC1025_eeprom??
Regards wolfgang
Regards wolfgang
- (39.14 KiB) Downloaded 915 times
- Dan81
Re: i2c macro
Hello Wolfgang
If you want to write from 0x 0 0000 to 0x 0 FFFF
try : Send Byte Transaction ( 0x50, hh, ll ,data)
If you want to write from 0x 1 0000 to 0x 1 FFFF
try : Send Byte Transaction ( 0x54, hh, ll ,data)
I suppose that A1 and A0 are connected to GND
I can't test it on hardware.
With "transaction" macros , you'll be able to write (or read) only 1 data at a time.
Sequential read or write could be interesting.
Daniel
Daniel
saschech@gmx.de
Harry Tuttle
- Has thanked: 2 times
- Been thanked: 10 times
Re: i2c macro
Is this what you should be seeing s,64,0,0,8,P?
This is version V4 of flow code.
Not sure what is wrong with yours!!!
saschech@gmx.de
Re: i2c macro
Hello Harry
I look for adresse :
a7 > 8 0
a6 > 0 0
a5 > 2 0
a4 > 0 0
___10 0 > hex 0xa0
The macro work:
a7 > 0 0
a6 > 4 0
a5 > 0 0
a4 > 1 0
____5 0 >hex 0x50 << 1 = 0xa0 = 160
You understand?
Regards Wolfgang
a7 > 8 0
a6 > 0 0
a5 > 2 0
a4 > 0 0
___10 0 > hex 0xa0
The macro work:
a7 > 0 0
a6 > 4 0
a5 > 0 0
a4 > 1 0
You understand?
Regards Wolfgang
- (98.89 KiB) Downloaded 874 times
