the VNet is a great feature my programs work fantastic in the simulation but i am having another problem if i program a Pic16F876 it works on the development board but if i program a PIC16F886 the upgraded version the chip dose not work i have tried changing chip settings and cant get it to work there must be something small i am doing wrong can you please help.
I am using a Cristal oscillator and i have tried changing to XT HS
Oscillator : HS
Watchdog Timer: 0ff
Power Up Timer: on
Master Clear Enable : /MCLR is external
Code Protect: off
Brown Out Protect: BDO & SBOREN disabled
Internal Esternal Switch over mode: disabled
monitor clock fail safe: enabled
Low Voltage Program: enabled
Background debug: enabled
Self Write Enable: no protection
Brown Out set bit: Brown out at 4.0V
