Hello !
I need to transform a 10bit int from an ADC into two 8bit byte to transmit it over RS232.
How to transform this and how to rebuild the 10bit int with the two 8bit byte ?
Thanks a lot for your help,
Mathy
How to transform a 10bit int into two 8bit byte ?
Spanish_dude
- Has thanked: 63 times
- Been thanked: 102 times
Re: How to transform a 10bit int into two 8bit byte ?
I would do something like this :
higher_byte = (ADC_value & 0xFF00) >> 8
lower_byte = (ADC_value & 0xFF)
EDIT:
To rebuild the value after reading it from the rs232 :
ADC_value = higher_byte << 8 | lower_byte
EDIT:
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Hi Mathy,
There's a great article about this kind of thing here:
http://www.matrixmultimedia.com/mmforum ... =26&t=7451
By the way, the "|" symbol means a bit-wise OR operation. In the example, you can also use a "+" operation.
Hi Mathy,
Take a look at:
http://www.matrixmultimedia.com/mmforum ... igh#p20779
It covers both
10bit into two 8bit
and
From two 8bit into 10bit
I don't disagree with anything posted so far, I just thought would add my 2p worth
Edit. Just read article Steve mentioned. It's definitely worth reading.... Thanks for the link
Take a look at:
It covers both
10bit into two 8bit
and
