French Loto
jeannot
French Loto
Post by jeannot »
Drawing of five numbers and a supplementary number.
Only defect a number can be draws several times .
This programm works with Eblock switch board and LCDboard.
Good luck.
LE LOTO.fcf
(9 KiB) Downloaded 233 times
Spanish_dude
Has thanked: 63 times
Been thanked: 102 times
Re: French Loto
Post by Spanish_dude »
To solve your problem use an array to store the value of the lotto numbers and check if the "new" number already is set in that array.
BR,
Salut,
Pour résoudre ton problème tu pourrais utiliser un tableau de bytes ou tu y "sauvegarde" les chiffres du lotto.
A chaque "sortie" de numéro tu vérifies si le numéro est présent dans le tableau de bytes.
Cordialement,
Nicoals L. F.
Re: French Loto
Spanish_dude wrote: use an array to store the value of the lotto numbers and check if the "new" number already is set in that array.
That's kind of what I did when I created a lottery number generator.
See http://www.matrixmultimedia.com/mmforum ... =26&t=8025
