RB.0 interrupt + RB.1 to RB.6 "IOC" on PIC16F887
- fotios
- Has thanked: 109 times
- Been thanked: 117 times
I was faced with this problem:
On PIC16F887 the "IOC" interrupt is available on all pins of Port B, while in old PICs is available only from RB.4 to RB.7. In my project i have connected an IR receiver in RB.0 and i have enabled the "INT" interrupt on this pin of PortB. I have connected six push-buttons from RB.1 up to RB.6 and i wanted to use the IOC interrupt offered from P16F887. For enabling the IOC interrupt on PortB, you have to select the "PORT" interrupt in Flowcode (corresponding to IOC interrupt of PIC) but it is applicable on all 8 pins of PortB, you can't exclude from this Port RB.0. If i remember well, i tried everything on "PORT" interrupt (RB.0 on, RB.0 off) to simulate the IR receiver interrupt like a momentary switch, but i failed. Then, to complette my project, i added an extra Loop inside the main Loop to scan the state of the 6 switches and i used just the "INT" interrupt on Port RB.0. The final program works absolutely right in the actual project, but i am curious to know if there is a way (i think it might be) of using both interrupts. External interrupt on Port RB.0 and IOC interrupt from RB.1 to RB.6. Maybe a custom interrupt?
Fotios
Fotios
Best Regards FOTIS ANAGNOSTOU
Re: RB.0 interrupt + RB.1 to RB.6 "IOC" on PIC16F887
Hello Fotios,
All you have to do is enable both the INT and Port interrupts and then use a line of C code in a C icon to mask off pin 0 from the Port interrupt.
iocb = 0xFE;Regards Ben Rowland - MatrixTSL
- fotios
Wow! It was so simple! You may know, that i am - almost - completelly irrelevant with PIC assembly and that i know few things about C language. Moreover, for this reason i bought Flowcode
I will try it (i am sure that it will work) in few days and i will inform you for the expected success.
Thank you Ben!
Fotis
Thank you Ben!
Fotis
Your welcome
I'll keep my fingers crossed for you
- Eric Brouwer
- Has thanked: 3 times
- Been thanked: 11 times
Fotios
I do not have a 16F887, but I did have a look at the datasheet, and hope this program might help you on this specific chip.
Please note that the PORT interrupt does not seem to simulate correct, it only works for RB4..7. But I am sure it will work correct in your application. I have added the buttons to RB1..6, and disabled pins RB7 and RB0 in the IOCB register. Thus the IOC will not generate an interrupt for changes on RB0 or RB7.
- 16F887_Interrupts.fcf
- (8 KiB) Downloaded 766 times
- fotios
@ Eric Brouwer
Thank you very much Eric! You are very kind.
Yes, i know that PORT interrupt does not simulated from RB.0 up to RB.3. In your thread "Using Interrupts to scan Keypad" there is a reply of Steve Tandy explaining this issue. That is no problem to me, because i use "real" hardware for testing programs. I am sure that it will works. I will inform you for this.
Thanks again
Fotis
Thanks again
Fotis
i cant open the fcf file, but i need to learn more about the IOC in the 16f887.
is it possible to post the code (again)?
this would be great!
thx
gabriel
thx
gabriel
- fotios
Hi Gabrielgabba-G wrote:Hello,
thx
gabriel
I downloaded and i opened the *fcf file of Eric, without problem using flowcode v4. You should know that i can't directly open *fcf files, i have to save these first on my HDD. Maybe this can resolve your problem?
Fotis
- AndreasR
- Has thanked: 5 times
- Been thanked: 3 times
I have a very strange problem with interrupts and i don´t know what´s wrong.
i tried the sample program (16F877_Interrupts.fcf) and all works fine
Then i created a brand new program, included an interrupt, choosed interrupt at Port and here comes the strange.
The properties of the port interrupt are greyed out. I can´t get anything.
What i do wrong?
Andreas
What i do wrong?
Andreas
often i ask myself:
why i´m not a gardener ?
Hello Andreas,
I have given this a go and the 16F887 is working correctly for me giving interrupt properties for the PORT interrupt.
The 16F877A does not give options for the PORT interrupt as the IOC mask register does not exist on this device. Instead you have to use software to decide if the interrupt was from a wanted or unwanted pin by retaining the port value from the last interrupt and using masking. Only pins RB4-RB7 can generate the PORT interrupt on this device.
- AndreasR
I see...
Shame on me.
It´s better to read all the instruction sheets of the PICs that i will use.
Tanks again
Andreas
Shame on me.
Tanks again
Andreas
often i ask myself:
