FAT16 component
achillis1
Has thanked: 91 times
Been thanked: 8 times
FAT16 component
Post by achillis1 »
Last time I used the FAT16 component was when I had flowcode version3 and it was a custom component.
Now that it is an enbedded component what settings should I use in the external properties and in the connection properties?
Also at which port should I connect the MMC board?
At some point I was discussing with Ben and I had an issue with the SD card used in the MMC board ( about the card type) and in order to fix that, Ben recomended that I should amend a text file for the FAT component. Is that still applicable or is ti fixed in V4?
Thank you
Andreas Achilleos
Re: FAT16 component
Please see here for the up to date FAT component code file for version 4.
http://www.matrixmultimedia.com/mmforum ... ion#p19450
The component connections and properties are documented in the component help file so this should help to get you started.
