18F67k22
saschech@gmx.de
Has thanked: 1 time
Been thanked: 26 times
18F67k22
Post by saschech@gmx.de »
Hello Team
I have different problem`s with these chip (also with the beta) !
At what time i can hope for a solution?
Regards Wolfgang
Re: 18F67k22
Hello Wolfgang,
What is the problem you are having?
saschech@gmx.de
Has thanked: 1 time
Re: 18F67k22
Hello Benj
I cant set config-bits and speed,show screen-shot`s
Regards Wolfgang
(120.71 KiB) Downloaded 1586 times
(49.38 KiB) Downloaded 1586 times
saschech@gmx.de
Has thanked: 1 time
Re: 18F67k22
Hello Benj
If i want compile....
Regards Wolfgang
(29.77 KiB) Downloaded 1582 times
Re: 18F67k22
Hi Wolfgang,
The first screenshot shows a 18F45K20, is this correct?
As for the configuration problems here is an updated set of configuration files for PPP that should allow this device to work correctly.
You will need to extract the files from the archive and then copy into your "Flowcode v4/Tools/PPP" directory.
PPP.zip
(1.18 MiB) Downloaded 308 times
saschech@gmx.de
Has thanked: 1 time
Re: 18F67k22
Hello Benj
The 18F45K20 can work with 64MHZ.....
set the config bits , work with the new ppp ok,
but compile to hex,i have the same error.
Regards Wolfgang
(17.3 KiB) Downloaded 1574 times
Re: 18F67k22
OK these definitions have now been fixed and will be included in the update.
Great thanks for letting me know.
I will see if I can get this fixed for you also.
Re: 18F67k22
Here is an updated FCD for the 18F45k20 device.
18F45K20.fcd
(13.3 KiB) Downloaded 330 times
saschech@gmx.de
Has thanked: 1 time
Re: 18F67k22
Hello Benj
Thank you for effort,but the file is for 18F45k20;
must i rename the file to 18f67k22 ; because i have compile rerror with this chip?
Regards Wolfgang
Re: 18F67k22
Hello Wolfgang,
Please try this FCD and ADC24 component C file and let me know how you get on.
I sent the other FCD because I got a PM from David saying you had requested this updated FCD.
PIC_ADC_24.c
(8.89 KiB) Downloaded 301 times
18F67K22.fcd
(15.89 KiB) Downloaded 283 times
saschech@gmx.de
Has thanked: 1 time
Re: 18F67k22
Hello Benj
I changing files without succsess.
Regards Wolfgang
(29.88 KiB) Downloaded 1557 times
Re: 18F67k22
Hi Wolfgang,
I noticed this in your command line parameters.
_ecio40pin
This should not be there!
Please can you go into the Chip -> Compiler options menu and click restore defaults and then see if this text is still present in your output window.
If you could upload your file to the forums then I will see if I can replicate your problem here.
saschech@gmx.de
Has thanked: 1 time
Re: 18F67k22
Hello Benj
I name my project _ecio40pinxxxxx because my print is the identical construction with the 18F67k22.
Your tip "take default`s" dos not fix the error.
So i start new with input macros....after a 2 adc i have the error ; the thame after i put in a pwm macro
Regards Wolfgang
(40 KiB) Downloaded 1550 times
(64.54 KiB) Downloaded 1550 times
_ecio40pin18F67K22.fcf
(124.5 KiB) Downloaded 226 times
saschech@gmx.de
Has thanked: 1 time
Re: 18F67k22
Hello Team
What can i do fix the error`s ? ; Because I cant go on with my project!
Regards Wolfgang
Re: 18F67k22
Hi Wolfgang,
The ADC is compiling correctly for us here on the new version using the files I previously attached so it must be a problem with the beta release of the compiler. We are in the process of testing the 4.5 release now so hopefully we will have something to fix your problem very shortly.
