Hi benj
Thanks for that ,
i am using a 16F884 I/P with the lcd conected to port A
These are the tests i have done
if i connect the led board (on its own) to port A i can see led led 0, 1 flashing - ok
if i connect my circuit and my display board to port A i cannot see anything on the display just the cursor flashing
if i connect the led board between my circuit board and my display no leds light
if i remove the lcd board and leave the led board conected some leds flash (Bit quick cannot fully see whats happened)
i Can test the flip flop action on bread board ok
if i replace the modified c code back to the original one my lcd display works fine
just realised today that the flip flops that i am using have a max o/p current of 2 Ma (surley that must be enough for a display ?) ordered some more from farnell going to try again tommorrow when i have picked them up ordered some with a 8 Ma and going to try a different port and a couple of different pics that i have lurking somewhere.
just a quick thought i am using a EB-16-00-2 board with J2 as a Male plug and J1 swapped for a Female with EB634 leads could that be my problem ?
attached is my circuit diagram which looks like your's
steve
