i need a component like a ** Rotary encoder for Input Device? Will you provide something like this?
Thanks Andy
components: Rotary Encoder with push button
Mark
- Has thanked: 20 times
- Been thanked: 16 times
Guys,
I have been interested in using a rotary encoder, however, there does not seem to be a standard device format? nor a commercial device that rotates freely with little force? Hope I am wrong?
I therefore made my own Grey code disc from etched PCB, (which is of course easy to interface) though it is a bit of a toy as it is not robust enough for prolonged use.
Mark
Mark
Go with the Flow.
Rotary encoder
My question regrading to the support in Flowcode3. I need a device wich i can direct implement in my code. or is there a trick
There are much Rotary encoder knobs on the market and you can reduce input device with a menΓΌ option in your program.
When using rotary encoders you have two options.
Sequential Coding - Binary position
Grey Coding - Binary position only 1 bit changes at a time
To implement one of these options requires different code.
Sequential Coding:
Read the binary position and use that to calculate position and direction.
Grey Coding:
Monitor the binary bits and monitor which bits are changing to calculate position and direction.
Then it is simply a case of resolution. Eg a rotary encoder with two bits will give a resolution of 360 / 4 states = 90 degrees.
Sequential Coding:
Grey Coding:
the trick with a men
I want to have a menΓΌ on my 12x2 LCD display and i will do this with a rotary encoder. Yes , it is a 20ppm Grey Code encoder with push button. The problem is not to check the status of the rotary direction or calculate the posission.
I wan't to know how the best programming in flowcode is. Should i use always an interrupt for every changes on Rotary knob and push button or is there a easy way to do this parallel with LCD -Display output.
It would be enought to check it every 1ms-10ms !?
How can /should this Routine can be parallelized with the display ,USB- Routine.
Can you use a routine like this
Infinite Loop
Read Encoder
Calculate position
Read push button
Update LCD
Delay 10ms
Infinite Loop
Read Encoder
Calculate position
Read push button
Update LCD
Delay 10ms
Rotary Encoder
I have been using a 10K continuous mechanical rotation potentiometer (Radiospares Number 460-2048) as a rotary encoder with some success for a long time. If fed 5 volts across the winding, the wiper can be read by a PIC ADC giving a voltage proportional to angle. The drawbacks are that there is a small dead spot of about 5 degrees (which can probably be solved by software), limited life (about 10,000,000cycles), mediocre weatherproofing and a bit of torque needed to move it. Cost in UK about Β£10.
