Hello!
I get the following error when I try to compile.
When I simulate all is fine, but not when I try to compile.
This program will control the PWM according to two ADC signals.
I use Integer for measuring variables so they can be both positive and negative. As I can understand, problem is in my IF statement "If U_res <-20. But it is Integer. It can be negative. So why is the problem here? Is there anyone who could possibly help me with that?
Very grateful for your help!
Flowcode1.c(1570): error: missing right paren
Flowcode1.c(1570): error: error in 'if' expression
Flowcode1.c(1570): error: missing semicolon
Flowcode1.c(1394): error: failure
failure
Return code = 1
FINISHED
Problems when compile the program_ Flowcode 4.5
- Flowcode V4 User
- Has thanked: 9 times
- Been thanked: 2 times
- Flowcode1.fcf
- (14 KiB) Downloaded 276 times
- Flowcode V4 User
- Has thanked: 17 times
- Been thanked: 1 time
Re: Problems when compile the program_ Flowcode 4.5
Hi Dmitry Maximenko
I try to solve your problem n it's succesful ( compiled without error ).
You must separate the variable with other thing/math ie . A = B + C ... cannot be A = B+C . Also A <= C ... cannot A < = C.
Your problem is typing error.
Zuki.
Zuki.
- Flowcode1_zuki.fcf
- (14 KiB) Downloaded 281 times
- Flowcode V4 User
HELLO Zuki!
thank you!
thank you!
Last edited by Dmitry Maximenko on Sat Oct 15, 2011 12:53 pm, edited 1 time in total.
- Flowcode V4 User
You mean the successful hex code ? I attached it below.
The flowchart that successful compiled ( tested ) is in my previous attachment 'Flowcode1_zuki.fcf'.
Zuki.
Zuki.
- Flowcode1_zuki.hex
- (5.22 KiB) Downloaded 259 times
- Flowcode V4 User
Below is the compilation history:
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
Flowcode1_zuki.c
Starting preprocessor: c:\PROGRA~1\MATRIX~1\FLOWCO~1\boostc\pp.exe Flowcode1_zuki.c -i c:\PROGRA~1\MATRIX~1\FLOWCO~1\boostc\include -d _PIC16F1827 -la -c2 -o Flowcode1_zuki.pp -v -d _BOOSTC -d _PIC16 -d _PIC16x -d _CHAR_INDEX
Flowcode1_zuki.c success
success
Return code = 0
c:\program files\matrix multimedia\flowcode v4\boostc\boostlink_pic.exe -ld "C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\lib" libc.pic16.lib flowcode.pic16.lib rand.pic16.lib float.pic16.lib "Flowcode1_zuki.obj" -t PIC16F1827 -d "C:\Users\zuki\AppData\Local\Temp" -p "Flowcode1_zuki"
BoostLink Optimizing Linker Version 7.03
http://www.sourceboost.com
Caution: argument of 'delay_10us' calls must have a value of 1 or more
Warning unreferenced functions removed:
FCI_FLOAT_TO_STRING in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCI_NUMBER_TO_HEX in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCI_STRING_TO_INT in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCI_STRING_TO_FLOAT in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
Wdt_Delay_S in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
isinf in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCD_ADC0_ReadAsByte in: C:\Users\zuki\AppData\Local\Temp\Flowcode1_zuki.c
FCD_ADC0_ReadAsVoltage in: C:\Users\zuki\AppData\Local\Temp\Flowcode1_zuki.c
FCD_ADC0_ReadAsString in: C:\Users\zuki\AppData\Local\Temp\Flowcode1_zuki.c
FCD_PWM0_Disable in: C:\Users\zuki\AppData\Local\Temp\Flowcode1_zuki.c
FCD_PWM0_SetDutyCycle in: C:\Users\zuki\AppData\Local\Temp\Flowcode1_zuki.c
FCD_PWM0_ChangePeriod in: C:\Users\zuki\AppData\Local\Temp\Flowcode1_zuki.c
FCD_LCDDisplay0_Clear in: C:\Users\zuki\AppData\Local\Temp\Flowcode1_zuki.c
FCD_LCDDisplay0_PrintASCII in: C:\Users\zuki\AppData\Local\Temp\Flowcode1_zuki.c
FCD_LCDDisplay0_Command in: C:\Users\zuki\AppData\Local\Temp\Flowcode1_zuki.c
FCD_LCDDisplay0_PrintString in: C:\Users\zuki\AppData\Local\Temp\Flowcode1_zuki.c
FCD_LCDDisplay0_ScrollDisplay in: C:\Users\zuki\AppData\Local\Temp\Flowcode1_zuki.c
FCD_LCDDisplay0_ClearLine in: C:\Users\zuki\AppData\Local\Temp\Flowcode1_zuki.c
FCD_LCDDisplay0_RAM_Write in: C:\Users\zuki\AppData\Local\Temp\Flowcode1_zuki.c
FCD_ADC1_ReadAsByte in: C:\Users\zuki\AppData\Local\Temp\Flowcode1_zuki.c
FCD_ADC1_ReadAsVoltage in: C:\Users\zuki\AppData\Local\Temp\Flowcode1_zuki.c
FCD_ADC1_ReadAsString in: C:\Users\zuki\AppData\Local\Temp\Flowcode1_zuki.c
Building CASM file
Memory Usage Report
RAM available:384 bytes, used:61 bytes (15.9%), free:323 bytes (84.1%),
Heap size:304 bytes, Heap max single alloc:95 bytes
ROM available:4096 words, used:956 words (23.4%), free:3140 words (76.6%)
success
Return code = 0
FINISHED
Flowcode1_zuki.c
success
Return code = 0
Building CASM file
Memory Usage Report
success
Return code = 0
FINISHED
