for help
nnnnff
Has thanked: 3 times
Been thanked: 6 times
for help
Post by nnnnff »
When V4 software choose language as "Chinese simplified", if the application in appeared "connection" figure operator program, the compiler will not pass, must fail!!!!! This is a very deadly bug in Chinese schools for the students to use.
Problem figure
Problem figure
Problem figure.JPG (40.01 KiB) Viewed 5717 times
Re: for help
hi nnnnff,
Have you tried on a PC that't set to Chinese?
This is only a complete guess so I could be wrong and maybe a bug? :P
I believe what's happening is:
If trying an a PC which has not got Chinese fonts but only displaying English, then when compiling to hex the word Main (but in Chinese) is not recognised since fonts used can't create the word main in Chinese.
If you have access to a pc that's set to Chinese language then would you mind testing my theory please?
nnnnff
Re: for help
Post by nnnnff »
I'm a Chinese university teachers, using the PC is the Chinese system, so find the deadly bug. Please help me. Thank you!
allpicproject
Flowcode V4 User
Has thanked: 17 times
Been thanked: 1 time
Re: for help
Post by allpicproject »
nnnnff wrote:I'm a Chinese university teachers, using the PC is the Chinese system, so find the deadly bug. Please help me. Thank you!
Can you upload the file if you don't mind ? Let me try.
Tq.
nnnnff
Re: for help
Post by nnnnff »
An example problem
Flowcode1.fcf
An example problem
(3.5 KiB) Downloaded 261 times
allpicproject
Flowcode V4 User
Re: for help
I'm not sure if it's flowcode bug or something else. I'm not use chinese version window.
Base on C file , suspect there something wrong within the main() function .
void main()
	//Initialisation
	ansel = 0;
	cmcon = 0x07;
	//Interrupt initialisation code
	option_reg = 0xC0;
	//Connection Point: [A]: A
FCC_???_A:
	//Output: 1 -> A0
	trisa = trisa & 0xfe;
	if (1)
		porta = (porta & 0xfe) | 0x01;
	else
		porta = porta & 0xfe;
	//Goto Connection Point: [A]: A
	goto FCC_???_A;
	mainendloop: goto mainendloop;
void MX_INTERRUPT_MACRO(void)
I tried some alternative ( make a new makro ) and it no problem ( using english window version ) and compiled perfectly.
c:\program files\matrix multimedia\flowcode v4\boostc\boostlink_pic.exe -ld "C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\lib" libc.pic16.lib flowcode.pic16.lib rand.pic16.lib float.pic16.lib "Flowcode1-zuki.obj" -t PIC16F88 -d "C:\Users\zuki\Downloads" -p "Flowcode1-zuki"
BoostLink Optimizing Linker Version 7.03
http://www.sourceboost.com
Warning unreferenced functions removed:
	 FCI_FLOAT_TO_STRING	 in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
	 FCI_NUMBER_TO_HEX	 in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
	 FCI_STRING_TO_INT	 in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
	 FCI_STRING_TO_FLOAT	 in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
	 Wdt_Delay_S	 in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
	 Wdt_Delay_Ms	 in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
	 isinf	 in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
Warning: function never returns: 'FCM_Test2'
Building CASM file
Memory Usage Report
RAM available:368 bytes, used:36 bytes (9.8%), free:332 bytes (90.2%),
Heap size:332 bytes, Heap max single alloc:110 bytes
ROM available:4096 words, used:89 words (2.2%), free:4007 words (97.8%)
success
Return code = 0
FINISHED
Flowcode1-zuki.fcf
(4 KiB) Downloaded 258 times
nnnnff
Re: for help
Post by nnnnff »
Choose English, compiled without problems.
Just in the choice of Chinese have compiled.
Ask for help. thank you
Has thanked: 114 times
Been thanked: 422 times
Re: for help
Post by Steve »
This is a known problem with the Chinese version of Flowcode v4. Basically, using a "connection point" in the "Main" flowchart will cause this problem.
This will be fixed in Flowcode V5. For a workaround, you can use the attached file. Unzip the attachment and copy it into your Flowcode directory. You may want to make a copy of the original FlowZHCN.dll file as a backup.
FlowZHCN.zip
(966.22 KiB) Downloaded 1521 times
nnnnff
Re: for help
Post by nnnnff »
Steve wrote:This is a known problem with the Chinese version of Flowcode v4. Basically, using a "connection point" in the "Main" flowchart will cause this problem.
Thank you very much. I hope to have the opportunity to meet you. I wish you a happy happy!
