configure remapping on 33FJ64
Mathy
Has thanked: 30 times
Been thanked: 33 times
Post by Mathy »
Hello :)
I'm trying to use more than 2 PWM on the dsPIC32FJ64.
I made some change to the PIC16BIT_PWM.c file but I don't understand how work the remapping settings.
For example, in the generated c file you have :
//configure remapping
RPOR0 = (RPOR0 & 0xFF00) | 0x0012; //Assign PWM OC1 - RP0 / PORTB0
RPOR0 = (RPOR0 & 0x00FF) | 0x1300; //Assign PWM OC2 - RP1 / PORTB1
How can I assign PORTB2 and PORTB3 for OC3 & OC4 ?
Thank you for your help :)
Re: configure remapping on 33FJ64
What is the full part number of the device so I can check the OC2 and OC3 values.
Probably something like this if OC3 is 0x14 and OC4 is 0x15.
RPOR1 = (RPOR1 & 0xFF00) | 0x0014; //Assign PWM OC3 - RP2 / PORTB2
RPOR1 = (RPOR1 & 0x00FF) | 0x1500; //Assign PWM OC4 - RP3 / PORTB3
Mathy
Post by Mathy »
Hello :)
Thank you for answering.
The full part number is 33FJ64MC802.
I tried with the code you gave me but without success.
I attached the .c file to see what I'm doing wrong.
Is the FCD file need to be changed ?
Thank you again :)
PIC16BIT_PWM.c
(7.34 KiB) Downloaded 273 times
Right I have had a look at the datasheet and the code I gave to you should be correct for remapping the extra PWM pins to RB2 and 3. I've also had a look through your PWM code and this also looks to be correct. The FCD I have is correctly listing 4 PWM channels so the code should be working. Does the code compile correctly for you?
Mathy
Post by Mathy »
Yes the code compile correctly.
I can generate the .hex file but I have only the two PWM channel active. The third and fourth are inactive.
