hi, thanks for the opportunity
Would you consider making the target Micro Pinout window sizable?
The reason for this is I use a high definition laptop to devlop on, and the individual pin / function displays are too small to use as an easy reference. this is apparent when using a laptop screen
thanks again
sizable Pinout window
RobZeilinga
- Flowcode V4 User
- Has thanked: 1 time
- Been thanked: 1 time
- JonnyW
- Has thanked: 63 times
- Been thanked: 290 times
Re: sizable Pinout window
Hi Rob. In v5 the chip window can be scaled to double its original size.
Cheers,
Jonny
Cheers,
Jonny
