Enhanced PWM
Jan Lichtenbelt
Has thanked: 128 times
Been thanked: 264 times
Enhanced PWM
Post by Jan Lichtenbelt »
Please find a very simple example program with enhanced PWM.
Used is a 16F1825 at 19.6...MHz.
The mode is half bridge drive with 2 outputs P2A and P2B, see picture below
half bridge drive.jpg (19.06 KiB) Viewed 2879 times
The 2 complementary outputs can be used for half bridge (motor) drive.
Driver rise time can be faster than falling time which will result in short current between V+ and ground. To prevent this the rise pulse must be delayed, see picture below
half bridge delay time.jpg (14.37 KiB) Viewed 2879 times
The practice oscilloscope pictures, see next page.
Refrences:
Pictures from: http://www.microchip.com/stellent/idcpl ... e=en546902
Test_Enhanced_PWM_16F1825.fcf
(8.5 KiB) Downloaded 321 times
Jan Lichtenbelt
Re: Enhanced PWM
Please find some oscilloscope pictures:
1. Both PWM's above each other
P2A and P2B above each other.jpg (75.08 KiB) Viewed 2878 times
2. Both PWM's at the same level
P2A and P2B at same level.jpg (75.97 KiB) Viewed 2878 times
3. The sum of both PWM, which clearly shows a dead time of 0.8 usec, as programmed in the Flowcode
0.8 usec PWM delay.jpg (78.52 KiB) Viewed 2878 times
