Hi people!
Is there anyone who has used Capacitive Sensing oscillator ?
Is very interested in how it works
Please recommend how I should get started:-)
Best Regards
Dmitry
Dmitry Maximenko
- Flowcode V4 User
- Has thanked: 9 times
- Been thanked: 2 times
jgu1
- Has thanked: 1135 times
- Been thanked: 299 times
Re: Capacitive Sensing oscillator
Hi Dmtri!
I have asked the same thing : http://www.matrixmultimedia.com/mmforum ... gu1#p28446
But it seems that there is not someone who has tried it in FC. But try to look at this link. there is another link from (PCBheaven) that shows a good example. Maybe it can give you an idea to do it in FC. if you can, I am very interested, as I write, you can even change as you wish.
Best regard
Jorgen
Best regard
Jorgen
Dmitry Maximenko
- Flowcode V4 User
Here is a very basic example of cap touch in Flowcode v4.5.
For a better cap touch output you should really repeat the loop several times and take an average of the reading.
- CapTouch.fcf
- (8 KiB) Downloaded 333 times
jgu1
Hi Ben!
Thak you for your examble, but I have unfortunately absolute no experience with C. Is it difficult for you to "Compile it to Flowcode".
Best regard
Jorgen.
Best regard
Jorgen.
Hello Jorgen,
Unfortunately coding the ADC channel and other parameters into a custom component would be quite tricky without creating a specific component front end and we are currently flat out with v5 development. I will have a think on it and see what I can come up with. There is not too much C code in the file. I think the main bit you have to change is the bits that assign the specific ADC channel.
jgu1
Hi Ben!
Ok Ben, thanks for your reply. Yes, I could imagine it's hard to do in CF. Still look forward to Ver.5.
best wishes
Jorgen.
best wishes
Jorgen.
I have improved the example a bit to include a variable to control the ADC channel in use and also included a loop to help filter the cap touch signal.
- CapTouch2.fcf
- (8.5 KiB) Downloaded 357 times
