Flowcode dsPIC student/home version
clee
Flowcode v5 User
Has thanked: 3 times
Been thanked: 3 times
Post by clee »
First post, hello all...
I have Flowcode for dsPIC and have a few questions about functions that may not be available on the home version.
I can't get interrupts to work, even the example file that came with FC doesn't work. Also when using a dsPIC with built in 16bit DACs there doesn't seem to be any output functions or macro libraries, is that something available with the full version or do you need to write that code as a C file?
Thanks,
very nice program so far.
Craig
Has thanked: 114 times
Been thanked: 422 times
Re: Flowcode dsPIC student/home version
Post by Steve »
Hi Craig,
Interrupts should work. Can you please post an example program with an explanation of what is going wrong.
We have not produced a Flowcode "component" for the DAC module within the dsPIC. But it looks like it is fairly easy to communicate with via C code.
clee
Flowcode v5 User
Post by clee »
Thanks for the reply Steve.
I've just started to experiment with the interrupts, but just loading Tutorial 17 that came with FC (dsPIC) doesn't seem to work. Monitoring the 2 variables, they always stay at zero and the 7 segment display never changes.
I'm running FC on an AspireOne netbook and copied the install disk to a USB drive to install (no optical drive). Maybe something didn't get installed?
Post by Steve »
What hardware and chip are you using?
Example 17 uses timer 1 which does not simulate in version 4. A way to simulate timers in v4 is to include a call to the interrupt macro as part of the main. This way every time you go through the loop the interrupt is called. You can then remove this extra call when using the hardware. This has all been sorted out for simulated timer interrupts in v5.
TUT_17_modded.fcf_pic16
(8 KiB) Downloaded 270 times
clee
Flowcode v5 User
Post by clee »
Thanks,
Is it just Timer1 that doesn't simulate, or timers in general for the dsPICS? I'm using the 33FJ128GP802
From the looks of it, timers in general do not simulate.
clee
Flowcode v5 User
Post by clee »
Ok, good to know.
nnnnff
Been thanked: 6 times
Modification examples
Post by nnnnff »
(8 KiB) Downloaded 324 times
