Two issues:
1st is very minor and may not be worth sorting?
1) Built in C code viewer will not let me paste text that’s stored on windows clip board by using Ctrl V keys. OK with right click and paste. So minor it’s not an issue for me, just thought I would mention it for when next updated ( if you feel it even should be corrected?)
2) I am using 4MHz osc. and target device is 16F883. Flowchart will not compile if using any custom setting of baud rate that’s not one of the standard settings
e.g 4900 or 2500
V5.1 Very minor issue + custom RS232 error
Re: V5.1 Very minor issue + custom RS232 error
Thanks for the bug spots. Regarding point 2 are you using a software UART? If so then this probably won't work for any non standard Baud rates. Hardware UART should be ok I think.
Thanks Ben.Benj wrote:Regarding point 2 are you using a software UART? If so then this probably won't work for any non standard Baud rates. Hardware UART should be ok I think.
Oops
I rushed that post bit.
With your user name in blue and your status being Flowcode V5 user, I thought you have left Matrix
