serial USB doesn't start
jadiflow
Flowcode v5 User
Has thanked: 19 times
Been thanked: 16 times
Re: serial USB doesn't start
Post by jadiflow »
Thanks Ben.
jan
jadiflow
Flowcode v5 User
Post by jadiflow »
OK, all is fine now, after updating the driver with the latest W7 driver from the previous post.
BTW From the USB component help screen you can click a link which gets you to the outdated driver that only installs in Vista compatibility mode and seems unreliable in W7.
Maybe that link should go to the new driver...
I have a question on the EICO-28 (PIC).
Downloaded the 'data sheet' but it doesn't tell me"
- where is that LED connected to, which port;
- can I still use any of the 4 timers, or does the USB module use a timers resource?
thanks,
jan didden
Linear Audio
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
Jan,
According to the diagram in the ECIO data sheet on page 3, the LED is connected to RA5 on ECIO28P or RE2 on ECIO40P.
Regarding the timers, I found no references to the timers in the Matrix supplied USB code for Flowcode 4 or 5. The Microchip data sheet of the 18F2455 does not refer to the timers in the USB section, so all of them should be available for your own use.
Jac
― C.S. Lewis
