ECIO pin-outs larger drawing please
For users of Matrix Multimedia Electronics software to discuss projects, circuits and any other electronics concepts.
peterashuk
Post by peterashuk »
I am trying to make a development board which uses an ECIO40P with an LCD display, keypad and some I/O lines.
The ECIO drawings in the documentation are so small that I can't read them properly, is there a bigger drawing?
Also, does anyone have a typical circuit diagram which shows how the ECIO is powered.
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: ECIO pin-outs larger drawing please
Post by JohnCrow »
Hi Peter
The EB061 base board for the ECIO data sheet may show you the information you need.
http://www.matrixmultimedia.com/product ... PHPSESSID=
It can also be powered by the USB cable.
Hi Peter,
I do agree the diagram is very small
If you use a pdf reader, then by holding down Ctrl and + then you can zoom in like this:
(88.82 KiB) Downloaded 1979 times
Hope this helps a bit
