I need a macro to setup the filter configuration for the CAN
module other than the init provided by FLOWCODE
(the filter IDs must be provided by other electronic module or DIP configuration)
I know similar is the set up for the TX_ID is the code below,the wich is redundant with the INIT setting, but I am getting
confused converting this code to Filter, since I am not "C" programmer,
can someone help me?
//this is the definition for setting the TX ID variable
static void FCD_CAN0_SetTxID(char buffer, char hi, char lo);
// this is the definition of the component macro FCD_CAN0_SetTxID
// Code_SetTxID
if (buffer > CAN_MAX_TX_BUF)
return;
#ifdef USE_INT_CAN
switch(buffer)
case 0:
C1TX0SID = ((hi << 5) | (lo >> 3)) & 0x00FF; //Transmit Buffer 0 S-ID
C1TX0SID = C1TX0SID | ((hi << 8) & 0xFF00);
break;
case 1:
C1TX1SID = ((hi << 5) | (lo >> 3)) & 0x00FF; //Transmit Buffer 1 S-ID
C1TX1SID = C1TX1SID | ((hi << 8) & 0xFF00);
break;
case 2:
C1TX2SID = ((hi << 5) | (lo >> 3)) & 0x00FF; //Transmit Buffer 2 S-ID
C1TX2SID = C1TX2SID | ((hi << 8) & 0xFF00);
break;
#else
char i;
char id_addr = TXBxSIDH(buffer);
//enable SPI
clear_bit(MX_CAN_CS_PORT, CAN_CHIPSEL);
FCD_CAN0_SPI_SendByte(CAN_WRITE); //CAN write mode
FCD_CAN0_SPI_SendByte(id_addr); //start writting at hi id address
FCD_CAN0_SPI_SendByte(hi); //send the Hi ID value
FCD_CAN0_SPI_SendByte(lo); //send the Lo ID value
//disable SPI
set_bit(MX_CAN_CS_PORT, CAN_CHIPSEL);
#endif
// then we call the component macro after in MAIN
FCD_CAN0_SetTxID(0, 86, 64);
Setting Filters in CAN without init for CAN
Re: Setting Filters in CAN without init for CAN
Are you using internal or external CAN?
You should be able to do everything using a Flowcode macro and some C icons.
Let me know and I will have a crack at putting together an example.
I am using internal CAN with a dsPIC30f4012, I was looking at the code,
but arrived seen that should be pretty similar to the
"set tx id", ie, a redundant code that overwrites the init settings...
Mikat
- Has thanked: 7 times
- Been thanked: 36 times
Hi.
So are you looking way to change RX filters and masks without init?
Because the TX "filter"(ID) has macro to change...
If you are try this:
Just put that code in the c code block.
And if you want to use flowcode variable like "filter2", just replace the 472 at the FCV_FILTER2..
Everything else should work (tested at 30f6012a), but those while loops I haven't tested, just used 10ms delays.
Mika
C1CTRLbits.REQOP = 4; //request to config mode
while( C1CTRLbits.OPMODE != 4 ); //loop untill config mode NOT TESTED!!
C1RXF2SID = 472 << 2; //filter 2 472
C1RXF3SID = 1626 << 2;
C1RXF4SID = 344 << 2;
C1RXF5SID = 192 << 2;
C1RXM1SID = 2047 << 2; //mask 1 2047
C1CTRLbits.REQOP = 0; //request to normal mode
while( C1CTRLbits.OPMODE != 0 ); //loop untill normal mode NOT TESTED!! And if you want to use flowcode variable like "filter2", just replace the 472 at the FCV_FILTER2..
Mika
Thanks Mikat, I tried to just open a C code block and paste your code but when I try to compile to the chip I get this errors:
I guess is my lack of C and probably I am doing some silly mistake
Would you attach a file that compiles to a chip? then I will see what I am missing in the flowcode setting.
thanks !!!
Launching the compiler...
C:\Program Files (x86)\Matrix Multimedia\Flowcode PIC24&dsPIC V4\Tools\MX_bats\pic16_C30_comp.bat "TEST CAN TX CHANGE" "C:\Users\Raul\Desktop\FLOWCODE" 30F4012
C:\Users\Raul\Desktop\FLOWCODE>pic30-gcc -c -mcpu=30F4012 -funsigned-char -fno-short-double -Os -I"C:\PROGRA~2\MATRIX~1\FLOWCO~1\Tools\MX_bats\..\C_tools\support\h" -I"C:\PROGRA~2\MATRIX~1\FLOWCO~1\Tools\MX_bats\..\MX_support" -Wall -std=gnu99 "TEST CAN TX CHANGE".c -o "TEST CAN TX CHANGE".o
TEST CAN TX CHANGE.c: In function 'FCD_CAN0_CAN_ReadRX_ID_and_Data':
warning: array subscript has type 'char'
TEST CAN TX CHANGE.c: In function 'FCD_CAN0_Init':
warning: large integer implicitly truncated to unsigned type
TEST CAN TX CHANGE.c: In function 'FCD_CAN0_GetRxData':
TEST CAN TX CHANGE.c: In function 'FCD_CAN0_SetTxData':
warning: unused variable 'i'
TEST CAN TX CHANGE.c: In function 'FCD_CAN0_SetTxID':
TEST CAN TX CHANGE.c: In function 'main':
error: syntax error before numeric constant
Error returned from [pic30-gcc.exe]
Return code = 1
Flowcode was unable to compile the flowchart's C code due to the following errors:
If your flowchart contains C code, please review this carefully. If your flowchart contains no C-code or you have thoroughly reviewed the code, contact Technical Support.
thanks !!!
Return code = 1
Could you post up your C file so we can see what line numbers 2179 and 2186 refer to? Flowcode program would also be handy so we can try a test compile here.
