Please some clearification for BT_EX1_Node_B-fc4
In BT_EX1_Node_B-fc4 when using inquiry command the StringRaed begins from INDEX = 0 but when check for OK response message you begins StringRaed from idx (1). why in first case begins with 0 and in the second begins with 1?
- BT_EX1_Node_B-fc4.fcf
- (10.5 KiB) Downloaded 242 times
- DavidA
- Has thanked: 58 times
- Been thanked: 258 times
Re: Please some clearification for BT_EX1_Node_B-fc4
I dont know why the read command starts at '1' but you could create a readout to the LCD showing what is in the entire returned string to find out
