Questions!
nnnnff
Has thanked: 3 times
Been thanked: 6 times
Questions!
Post by nnnnff »
I'm using the "CAN", discovered a problem, as long as "CAN Init" later, the simulation is possible. But after downloaded to the chip can't normal operation! Even reset also can't run. For example a flash。Please help me!
led flash.fcf
(7.5 KiB) Downloaded 275 times
nuwan5213
Has thanked: 24 times
Been thanked: 4 times
Re: Questions!
Post by nuwan5213 »
hi nnnff,
try to increase the delay time more than 100ms.
i mean 500ms may be 1s.
in real world i think you cant see 100ms .because your eye is not response.
can int is not the problem.
regards.
nuwan..
Electronics for better world.
DavidA
Has thanked: 58 times
Been thanked: 258 times
Re: Questions!
Post by DavidA »
This is working as intended, the CAN Init function has a while loop in it that waits for a valid CAN return message before it moves out of the initialiser icon, so, in other words, dont use CAN Init unless you are in a valid CAN network :)
nnnnff
Re: Questions!
Post by nnnnff »
DavidA wrote:Hi,
Thank you very much! :D
