Timming issues Flowcode to target 16F684
Collimare
Been thanked: 2 times
Post by Collimare »
I have downloaded the following code into the target and I have a programmed LED 1 second on time that is 5 - 6 seconds at the target.
What do I need to do to to get them to equal. Thanks, Howard
Test16F684.fcf
(6 KiB) Downloaded 361 times
DavidA
Has thanked: 58 times
Been thanked: 258 times
Re: Timming issues Flowcode to target 16F684
Post by DavidA »
please see this post by medelec, it gives some good advice on clock settings:
If you are still struggling post back.
http://www.matrixmultimedia.com/mmforum ... =26&t=6936
Enamul
Has thanked: 271 times
Been thanked: 814 times
Post by Enamul »
Hi Collimare,
You have to use 19.66MHz crystal for the attached program but if you want to use other than that..you have to change that in Build>General options tab>Clock speed and also in Configure Chip you have to set correspondingly.
I have attached here a picture of configure...
Enamul
Test16F684.fcf
(6.5 KiB) Downloaded 336 times
Enamul
University of Nottingham
enamul4mm@gmail.com
