USING ADC WITH 16F88
siliconchip
Has thanked: 101 times
Been thanked: 25 times
Post by siliconchip »
being fairly new to flowcode i am experimenting using the ADC on the pic16f88 i have set the ADC to read up to 10V and display it on an lcd but i have 1 issue is it possible to go up in volts such as 1.1 - 1.2 - 1.3 etc up to 10V instead of 1V increments, any help would be gratefully appreciated
Flowcode1.fcf
(10 KiB) Downloaded 361 times
electron67
Has thanked: 106 times
Been thanked: 48 times
Re: USING ADC WITH 16F88
Post by electron67 »
The problem is the PIC work to 5 volt, you can use a voltaje divisor, 2 resistor de 10 k in series and one pin to +5 volt, other to gnd and center to PIC; multiply x2 and read voltaje in LCD
siliconchip
hi electron67 i understand that the pic operates on 5v but i would like the LCD to read a voltage other than 1v increments ie 0.1 - 0.2 then further along 1.1 1.2 1.3 etc
Hi siliconchip,
What about looking here:
http://www.matrixmultimedia.com/mmforum ... 99&p=20326
I posted A voltmeter that reads 0 - 15.00V (to two decimal places.)
It can be adapted for different scales. E.g remove *3 to read 0 - 5.00V
You can easily adapt it to read 0 to 10.00V
because its using int and with pic maths, there is small tolerance error.
siliconchip
hi martin thanks ive adapted the download just need to test on hardware now once again you have come up trumps thank you
bob
Your welcome, lets hope it works on your hardware :)
siliconchip
if it does'nt i will be back :wink:
