C-Error due to filename
Jan Lichtenbelt
Has thanked: 128 times
Been thanked: 264 times
Post by Jan Lichtenbelt »
Whatever can be is error message? (fout=error, resultaten=results)
I substract 2 integers: RC_Time_on=RC_Time_On - RC_Center. But this gives an error?????????
Who can help?
Kind regards
Jan Lichtenbelt
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: Error substracting 2 integers
Post by JohnCrow »
Hi Jan
Thats a strange one.
Ive just tried a simple flowchart using your variable names, and it works regardless of which value is the larger.
Are you using any C code, I think fout is a file command in C.
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
Jan,
A simple test program with just an integer subtraction works fine so it is probably something specific to your total program. PM the file if you want me to take a look.
Groeten,
Jac
― C.S. Lewis
kersing
Post by kersing »
John,
As Jan stated, fout is the dutch translation of error. He was referring to the message at the bottom of the screen dump "Foutresultaten", "Error results" when using the English language setting.
fout is a standard construct in C++, not in C afaik.
Best regards,
Jac
― C.S. Lewis
JohnCrow
Post by JohnCrow »
Yes, I see what Jan was refering to now.
Ah well it was the end of the day :)
Jan Lichtenbelt
I have the feeling that it has to do with the ROM use (97%), but I'm not sure, see msg.txt file.
Jan Lichtenbelt
RC_to_Motor_V20_12F1840.msg.txt
(6.25 KiB) Downloaded 305 times
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Post by JonnyW »
Good morning Jan.
At a guess is the line that the error is showing up on line 1840 of the generated .c file?
It may be that the parsing is getting mixed up as to what is an error and what is not. How the error report works is it looks at the compiler output for the filename and a line number (we can not even guarantee the word 'error' is present). If it finds the .c files name and a line number it can link to an icon, it reports this in the error window.
I'd be surprised if this is the case, as the parser should see 12F1840 as a single word and discard it, but I'm at a loss from the msg.txt to find anything else that could cause this.
Jonny
Jan Lichtenbelt
Dear Johnny,
You are right. The error is on line 1840/1841 of the C-program. Changing the flowcode filename into test.fcf did not give this error message anymore.
Thanks a lot for help!!
Kind regards
Jan Lichtenbelt
JonnyW
Post by JonnyW »
How very odd. Thanks for letting me know - I'll look into this as I've been looking at the code this morning and cant see why this would be!
Cheers,
Jonny
Jan Lichtenbelt
C error on text equal filename
Again in a complete other situation, I get an error in C on the place where the text in C is equal to the filename. Now the error is in the first comment, which indeed contains the filename. The filename in this case is "RS232 RX flowcode_V2.2". The error given is in the comment which contains: "RS232 RX flowcode".
Remark: Foutresultaten means error results.
(385.46 KiB) Downloaded 1168 times
It stays indeed very odd, but consistent.
kind regards
Jan Lichtenbelt
