Is it possible to get the .fcd files for the PIC16(L)F1516/7/8/9 family devices?
Supports the BoostC Compiler these family devices?
kind regards,
Support of PIC16(L)F1516/7/8/9 family
- DavidA
- Has thanked: 58 times
- Been thanked: 258 times
Re: Support of PIC16(L)F1516/7/8/9 family
Im not sure whether these devices are supported by Boost C or not, but we can certainly think about adding these to a patch in the future for Flowcode v5.
Is a time frame estimate or is the update only on the wish list?
Are you interrested to these files when I create my own?
are the required files already available now or do I still create these yourself?
Because I'm trying to create the file yourself and have unfortunately a few problems in understanding the FCD files.
Is there any detailed instructions on how to build the files are and which line is responsible for what?
Yours sincerely,
Yours sincerely,
I have had a look at the compiler that comes with Flowcode v5 for PIC and unfortunately it does not currently support the 16F15xx range of devices.
These devices are available in the latest version of the compiler so in the next update release we should be able to provide full support for these devices including the FCDs.
We normally control the FCD files and generate them where possible on a user's request if they are not already part of the Flowcode package.
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Is that possible to get the PIC IC in target IC list in Fc V4.
Enamul
According to above comment, I am clear that Boostc 7.0 is not able to compile 16f15xx family but I think Hitech C can compile those..So can you please tell here how to do that...I have had a look at the compiler that comes with Flowcode v5 for PIC and unfortunately it does not currently support the 16F15xx range of devices.We normally control the FCD files and generate them where possible on a user's request if they are not already part of the Flowcode package.
I mean if I make PIC16f15xx.h and PIC16f15xx.fcd file for any particular pic and add that in BoostCPic16.hIs it possible to get the .fcd files for the PIC16(L)F1516/7/8/9 family devices?
Enamul
