FC Compile Error
Enamul
Has thanked: 271 times
Been thanked: 814 times
FC Compile Error
Post by Enamul »
Has anybody ever seen this type of problem? Can anyone help me to sort out the problem? There is no C code in flow chart.
Enamul
Enamul
University of Nottingham
enamul4mm@gmail.com
Enamul
Re: FC Compile Error
Post by Enamul »
Powering down the PC and then re-launching Flowcode seems to have cleared this up. Any ideas as to why it happened?
Enamul
enamul4mm@gmail.com
Spanish_dude
Has thanked: 63 times
Been thanked: 102 times
Post by Spanish_dude »
Seems like you weren't running Flowcode as host.
Flowcode is trying to access the compiler at C:/program files/... probably and those folder are protected. Only host can request/open stuff from there like asking the compiler to compile your code.
That's my guess.
Nicolas
DavidA
Has thanked: 58 times
Been thanked: 258 times
Post by DavidA »
The Boost C licence we use only allows Boost C to be run from within Flowcode, to stop people using Boost C as a standalone compiler, this can sometimes happen if Boost C cannot be detected for some reason, ie Another version of Boost C is already loaded or it has been removed from the install, if a reboot has fixed it, nothing to worry about :)
Enamul
Post by Enamul »
Thanks David and Nicolas for the information. I am using Flowcode in the university machine where I have administrative privilege but I guess it happened to be changed in some case and this happens then.
Thanks,
Enamul
Enamul
enamul4mm@gmail.com
