config settings
Steve001
Has thanked: 460 times
Been thanked: 523 times
config settings
Post by Steve001 »
Afternoon All
not used my flowcode for ages now :( just come to have a play with some programes and am having some problems
bit a a loss as whats wrong
if someone could point me in the right direction again please :oops:
DavidA
Has thanked: 58 times
Been thanked: 258 times
Re: config settings
Post by DavidA »
Hi Steve,
These are the default parameters i think:
Default Parameters – PIC
Compiler:
Location: C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic16.flowcode.exe
Parameters: -v -t PIC%p "%f.c"
Linker/Assembler:
Location: C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostlink.pic.exe
Parameters: -ld "C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\lib" libc.pic16.lib flowcode.pic16.lib rand.pic16.lib float.pic16.lib "%f.obj" -t PIC%p -d "%d" -p "%f"
Programmer:
Location: C:\Program Files\Matrix Multimedia\Flowcode V4\tools\PPP\PPPv3.exe
Parameters: -cs 2 -chip PIC%p -nogui "%f.hex"
[TICKED] “Use external program to set configuration options”
Location: C:\Program Files\Matrix Multimedia\Flowcode V4\Tools\PPP\PPPv3.exe
Parameters: -cs 2 -chip PIC%p -config
Steve001
Re: config settings
Post by Steve001 »
thanks david,
i am using win 7 pro those setting look as if they are for xp ? is that correct
as C:Program Files dosen't contain my matix stuff.
it is in C:\program files (x86)\matrix multimedia\
please correct me if i am wrong
I have the following settings
compiler location is
c:\program files (x86)\matrix multimedia\flowcode v4\boostc\boostc_pic16_flowcode.exe
-v -t PIC%p "%f.c"
Linker/Assember is
c:\program files (x86)\matrix multimedia\flowcode v4\boostc\boostlink_pic.exe
-ld "C:\Program Files\SourceBoost\lib" libc.pic18.lib "%f.obj" -t PIC%p -d "%d" -p "%f"
Programmer
C:\Program Files (x86)\Matrix Multimedia\Flowcode V4\Tools\PPP\PPPv3.exe
External config option thing
steve
DavidA
Re: config settings
Post by DavidA »
Hi Steve,
The paths i posted were for a 32bit operating system, for a 64bit operating system you would use "Program Files (x86)" for Flowcode, as it is a 32bit application being emulated on a 64bit OS.
-ld "C:\Program Files (x86)\SourceBoost\lib" libc.pic18.lib "%f.obj" -t PIC%p -d "%d" -p "%f"
You may need an x86 in the linker parameters too
Steve001
Re: config settings
Post by Steve001 »
Bit confused with this now . .
c:\program files (x86)\matrix multimedia\flowcode v4\boostc\boostlink_pic.exe -ld "C:\Program Files\SourceBoost\lib" libc.pic16.lib "Flowcode1.obj" -t PIC16F887 -d "C:\Users\Ste\Desktop\Digital pot test" -p "Flowcode1"
BoostLink Optimizing Linker Version 7.03
http://www.sourceboost.com
i understand this bit
libc.pic16.lib "Flowcode1.obj" -t PIC16F887 - this is my chip
C:\Users\Ste\Desktop\Digital pot test" -p "Flowcode1" - this is my file
i cannot find SourceBoost folder ?
looked in C:\Program Files\ and c:\program files (x86) and c:\program files (x86)\matrix multimedia
is this where my problem lies ?
i have not use my flowcode for several months now dont understand why it's not working nice my last time i opened and used it ?
Re: config settings
These are settings for win7 64bit:
Compiler:
Parameters:
-v -t PIC%p "%f.c"
Linker/Assembler
Parameters:
-ld "C:\Program Files (x86)\Matrix Multimedia\Flowcode V4\BoostC\lib" libc.pic16.lib flowcode.pic16.lib rand.pic16.lib float.pic16.lib "%f.obj" -t PIC%p -d "%d" -p "%f"
Programmer:
C:\Program Files (x86)\Matrix Multimedia\Flowcode V4\tools\PPP\PPPv3.exe
Parameters:
External Program to set configuration options:
Parameters:
Problem you having is compiler/inker directory has to be \boostc\ and not \SourceBoost\
So maybe you have used other software like C or ASM for PIC?
Steve001
Re: config settings
Post by Steve001 »
:D :D :D :D :D
Cheers Martin dont know why thats happend ?
i have however reinstalled ASMV4PICS and having another go with it has that altered the settings ?
so will i have to keep altering the compiler setup each time between flowcode & ASMV4PICS ?
steve
Re: config settings
No problem.
What about restore default in compiler options?
If that restores it wrong, then what about editing registry?
See:
http://www.matrixmultimedia.com/mmforum ... =26&t=6896
Its a great article Steve created.
Steve001
Re: config settings
Post by Steve001 »
i did a restore defaults bit this restored wrong for some reason .
thanks for the link to the reg edit post will have a go at that later . need to read it fully first and understand it there is some strange symbols in there at the moment so i need to read it carfully.
Thanks again mate
steve :D
Enamul
Has thanked: 271 times
Been thanked: 814 times
Re: config settings
Post by Enamul »
Hi Steve,
I have read through the post of reg config yesterday after seeing the post here..Yes, you are right. Some strange characters in the post and that's all are in the important places. I think I would PM Steve to edit that which will avoid confusion.
But really a nice post..
Enamul
University of Nottingham
enamul4mm@gmail.com
Re: config settings
I see what you you mean about strange characters
The cause of those was due to updating forum software in Jan 2008. Some fonts and images got corrupted.
Here's want you can do Steve.
The link I posed does show you the location within the registry where default compiler setting are.
So you could either change settings to correct settings, or re-install Flowcode which should override the wrong settings.
Latter should be done as last result just in case of addition fixes, custom codes etc.
If your reluctant to do that then attached is a reg file for you to click which should sort out your issue.
Flowcode Default with PPP64Bit.zip
(641 Bytes) Downloaded 335 times
Steve001
Re: config settings
Post by Steve001 »
one again thanks :D
one question tho what will happen when i open asm4pic ? and have a go with that will i be back with the same problem ?
Re: config settings
Hi Steve,
No I don't think so, simply running the program shouldn't change the registry which is where the Flowcode compiler options are stored.
