PICkit3 + Lead + Demo board from RS £28 + Vat!
For users of Matrix Multimedia Electronics software to discuss projects, circuits and any other electronics concepts.
RS Components are selling this:
(190.16 KiB) Downloaded 11535 times
Part number is:
754-5112
Link:
http://uk.rs-online.com/web/p/processor ... 4E4F4E4526
You can see the demo board in action here:
http://www.youtube.com/watch?v=aSEfjhqvgN8
for £33.60 You get a fully working demo board with LCD, RTC, 8 LED's. POT touch sensors (with LEDs) etc that runs on a AAA battery (included), PICkit3 programmer + USB lead for programmer.
The demo board does have software loaded so you can use touch pads, plus see LCD and Analoge channel working etc.
Over time, I will be posting some flowcharts that will allow you to use the functions of demo board.
I have posted this before develping flowcharts just in case this low price if for a limited period only?
So if you want a new PICkit3 best get in as soon as you can :)
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: PICkit3 + Lead + Demo board from RS £28 + Vat!
Post by JohnCrow »
Great You-tube video :)
Thanks John,
Here are some useful links:
For schematic and BOM so you can see what RTC is used and LCD connections etc:
http://www.microchip.com/pagehandler/en ... /home.html
Learning about mtouch:
http://ww1.microchip.com/downloads/en/A ... 01101a.pdf
http://ww1.microchip.com/downloads/en/A ... 01102a.pdf
http://ww1.microchip.com/downloads/en/A ... 01103a.pdf
Enamul
Has thanked: 271 times
Been thanked: 814 times
Post by Enamul »
None of the above link works..same as you told to David. Links are not fully linked..
I was tempted by your post..thinking to buy one.
Enamul
University of Nottingham
enamul4mm@gmail.com
Sorry, edited and tested links.
All now working
DavidA
Has thanked: 58 times
Been thanked: 258 times
Post by DavidA »
Its a very neat little board!
JohnCrow
Post by JohnCrow »
Mine arrived today.
Great value especially as 1 component supplier is asking £46 for the pickit3
DavidA wrote:Its a very neat little board!
I totally agree. board is thin, and light as well.
JohnCrow wrote:Mine arrived today.
I also agree with that. It's well worth getting for programmer alone. Demo board is just a bonus lol
I have posted a flowchart that will provide some functions.
E.g showing current time from RTC, swich function and LEDs incrementing + dipsling pot value here:http://www.matrixmultimedia.com/mmforum ... 47&t=11324
But there an issue of freezing when post is activated.
Therefore I have altered flowchart so if shorting link is connected between pins 3 & 4 of ISCP, then pot is effectively disconnected.
Flowchart for 8bit can be found here:
Before you load flowchart, its best to make a backup of original software as it's not write protected.
To enable 8bit pic, two row jumper is connected horizontal and from left pins to middle.
To enable 16bit pic jumper is connected vertical and from left pins to middle.
To enable 32bit pic jumper is connected vertical and from right pins to middle.
JohnCrow
Post by JohnCrow »
Thanks Martin
Yes, thats something that I had thought of, copying the demo files first.
Had noticed one thing, MPLABX does not support the PICKIT2, wasn't sure yesterday if it was a driver problem, but plugged the PICKIT3 in tonight and it works straight out of the box
Not sure if I posted this link before but its a good review of the early PICKIT3, and Microchips (well taken) response to the review.
Worth taking the time to watch both of them
http://www.eevblog.com/2009/10/21/eevbl ... er-review/
Thanks for that link John, the videos are brilliant!
Good to see that a huge company like Microchip listen to the public and have a sense of humor to boot.
jollybv
Flowcode v5 User
Has thanked: 81 times
Been thanked: 25 times
Post by jollybv »
Hi Guys
Can i program straight form flowcode using my PickIt 3 programmer if so can anyone help me with the settings??
thanks
Brian
Hi Brian,
Have you read this:
http://www.matrixmultimedia.com/support ... f=22&t=565
jollybv
Flowcode v5 User
Post by jollybv »
Thanks for the advice but still not working this is how i have set it up
programmer Location to
C:\Program Files\Matrix Multimedia\Flowcode V5\Tools\PICkit3\pk3cmd.exe
The Parameters to
-P%p -F%f.hex -E -M -Y
The external programmer set configuration is ticked
Location is
C:\Program Files\Flowcode\v5\Tools\PPP\PPPv3.exe
I have tried both Parameters
-P%p -F"%f.hex" -E -M -Y"%f.hex"
-cs 2 -chip PIC%p -config
And im still getting Hex file not found return code 1 is there any other suggestions??
Are your paths to the Flowcode application correct?
By default flowcode v5 is installed in the following location.
C:\Program Files\Flowcode\v5\Tools\PICkit3\PK3CMD.exe
Or for a 64-bit version of Windows
C:\Program Files (x86)\Flowcode\v5\Tools\PICkit3\PK3CMD.exe
jollybv
Flowcode v5 User
Post by jollybv »
The path you talking about is that in the compiler options programmer if so yes
Hi Brian,
I'm a bit confused.
I can see you're a Flowcode V4 registered user, so I posted link for Pickit and FC4
However paths given are for FC5
Have you got an issue with FC4 or FC5?
Link for Pickit3 & FC5 is:
http://www.matrixmultimedia.com/support ... f=68&t=786
jollybv
Flowcode v5 User
Post by jollybv »
I have a problem with V5.5.2.1
Have you got any spaces within your file name?
If you have than that will cause a failure to compile.
Instead of spaces you can use underscore.
jollybv
Flowcode v5 User
Post by jollybv »
Thanks Medelec
That seemed to sort the problem out i also found that i needed to close MPLAB it was also conflicting
