preset
Re: preset
Hi Donald,
How about this?
How about this?
- timer.fcf
- (7.5 KiB) Downloaded 317 times
Re: preset
Mr. Benj, if I want to illuminate an led after finishing counting 9999, where you have to put the led?
- timer 2.fcf
- (8.5 KiB) Downloaded 313 times
Re: preset
Right now, I have noticed that he was without a stop --> 0, -1, -2, etc. It would have been better if from 0000 it is stopped and an led lights up.
Re: preset
Hi donald,
One way is in attached flowchart.
- timer3.fcf
- (9 KiB) Downloaded 329 times
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Re: preset
Here is it..what you are looking for..
- timer 2.fcf
- (9 KiB) Downloaded 317 times
Re: preset
Fantastic, are overwhelmed by your help Sir Martin, Enamul and Benj. Indeed it works as far as I want, thank you very much.
Re: preset
Hi donald,
Your welcome.
If you would like me to alter flowchart, so LCD is always showing 4 digits e.g
9999
0002
0001
0000
Also the numbers can be fixed so it does not move to the right when changing i.e most right digit can be fixed at x5 for example.
So you can have:
Etc.
Then let me know if you want any changes and I can alter flowchart for you
Your welcome.
9999
0002
0001
0000
So you can have:
345
15
7Then let me know if you want any changes and I can alter flowchart for you
Re: preset
Thank you very much sir Martin, I understood and I have proved and it works as you say.
For 5 digits what it has to be done?
Thanks in advance
Thanks in advance
- timer 4.fcf
- (9 KiB) Downloaded 318 times
Re: preset
Hi donald ,
I have created flowchart that can count from 99999 to 0.
See:
http://www.matrixmultimedia.com/mmforum ... 26&t=11343
Its a bit more complicated than counting from 9999 to 0 since maximum number LCD will display from and integer is 32767
See:
