I have a problem and cannot solve it, I have FlowCode V4, and I made a board of my own, with a PIC16f886, and an LCD 16x1.
I am only trying to display "Hello Word", and I only get the first 8 digits on the LCD, that is "Hello Wo". I have, HS for the Oscillator, BOD and SBOREN disabled, LVP disabled, and everything else disabled. The crystal is running at 12MHz and runs perfectly.
Could you help me on this, for I do not know what I am doing wrong, I have tried everything I know, and it keeps doing the same. The simulator works fine, for it is a very simple program, but in the real world…..
Thank you a lot, I will really appreciate it. My e-mail: elneto53@hotmail.com
Ernesto Carrion
My LCD only prints the first 8 of 16 digits
- STibor
- Has thanked: 116 times
- Been thanked: 113 times
Re: My LCD only prints the first 8 of 16 digits
Hi!
Program:
1.Lcd Display Start
2.Print String:"Hello Wo"(First 8 characters)
3.LCD Cursor:0,1 (Cursor to second line)
4.Print String:"rd"(Second 8 characters)
Program:
1.Lcd Display Start
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Can you please post your program? It seems to me that speed problem if nothing else is causing in the code.am only trying to display "Hello Word", and I only get the first 8 digits on the LCD, that is "Hello Wo".
In single line LCD, he has no scope to move to 2nd line..3.LCD Cursor:0,1 (Cursor to second line)
Please try the attached code and let us know how you are getting that.
- LCD_single_line.fcf
- (5 KiB) Downloaded 657 times
- STibor
Sometimes the one-line 16-character LCD display with 2 lines and 8 control characters.
Hellow STibor:
Thank you for your help, but, It does the same, it only prints the first 8 of 16 digits.
Below is the "C" code.
And I also think it is a speed problem, as you can see it is only a test program.
The cristal is a 12MHz cristal, it oscilates perfectly. atached you will find the configuration, and the FlowCode.
It does not respond to moving the cursor to the second 8 digits, it does nothing.
I must point out, that I custom wire the port "B", as you can see in the code, could that be the problem? I did this, for I have done it for AVR's without any problem.
Than you a lot for your help.
Ernesto.
Ernesto.
- compiler_msg.txt
- (12.08 KiB) Downloaded 680 times
- This is the FlowCode
- FlowCode2.jpg (100.47 KiB) Viewed 12702 times
- This is the micro configuration
- FlowCode1.jpg (51.97 KiB) Viewed 12702 times
Hola
Trate tabla enamuls, una cosa que me di cuenta es en el código C que parece poner el cursor a partir de las 8 de manera comenzará en la mitad posterior deEl lcd
después del inicio lcd macro agregar una macro cursor con 0 0 en el mismo
esto obligará a la pantalla para comenzar en la posición 0
háganos saber cómo le va
Saludos
Dazz
Try enamuls chart, one thing i noticed is in the C code it seems to set the cursor starting at 8 so will start in the later half ofthe lcd
after the start lcd macro add a cursor macro with 0 0 in it
this will force the display to start at position 0
let us know how you get on
Dazz
Saludos
Dazz
Dazz
Thank you for your input, but it does the same thing, I solved the problem, by printing 3 times the same string into the LCD, only the string had to be exactly of 16 characters, I really do not know why, but it seems that if I refress the LCD finally it gets the info, and prints the string.
Maybe this will tell you something about the problem.
Thank you a lot
Ernesto.
Thank you a lot
Ernesto.
- Enamul
I have found a solution for you. Although I was thinking Stribor was wrong..But he is right if my guess is right..The LCD you have is of 16*1 LCD type 1 which has RAM address from 0x00 to 0x07 (in first 8 charecters) and 0x40 to 0x47 (in next 8 characters). So using Flowcode and single line LCD it will not work..In the code I have changed that to LCD (16*2) to adjust address location..so please try that one and let us know.
Edit: Added FCV4 version for you...
- LCD_single_line_v4.fcf
- FCV4
- (4.5 KiB) Downloaded 664 times
- FCV5
- (7.5 KiB) Downloaded 656 times
