Servo with arduino uno
- Has thanked: 12 times
- Been thanked: 1 time
I'm stuck trying to get a servo to work on my uno, the error says if my program contains C. Works fine on the mega adk board but not the uno. I've tried all different pin outs with no joy
- Untitled.jpg (79.02 KiB) Viewed 3499 times
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Re: Servo with arduino uno
Can you please post a bit better resolution picture..it's not clear.
Thanks,
Thanks,
hope that's better? the flowcode works ok till i try and load to the uno
- Untitled.jpg (231.26 KiB) Viewed 3494 times
Please ensure that your servo component is set to only use the number of servo's you require in your program. Also please ensure that all the servo's are connected in the connections window.
If your still having compilation errors then this updated component C file should solve the issue.
Simply place into your "Flowcode (AVR)/v5/Components" directory.
Let me know how you get on.
