measuring battery voltage
Ondra
Been thanked: 2 times
Post by Ondra »
Good day All.
I want to use the PIC to measure battery voltage up to 7.4 volts. Can someone point me in the direction where I can find
a circuit and code example? Thanks in advance.
Ondra
Enamul
Has thanked: 271 times
Been thanked: 814 times
Re: measuring battery voltage
Post by Enamul »
Here is a voltmeter that can be used up to 10.2V..I forgot to mention one thing..you have adjust adc voltage such a way that when your input voltage is 10.2; the voltage at adc pin should be 5v. Bcz voltage at PIC input can't be greater than 5V.
Voltmeter.fcf
(11 KiB) Downloaded 369 times
Enamul
University of Nottingham
enamul4mm@gmail.com
