SPI Slave
Mathy
Has thanked: 30 times
Been thanked: 33 times
SPI Slave
Post by Mathy »
Hello !
Is someone already changed the existing SPI macro to make a SPI slave ?
It will be very usefull to me :)
Thank you !
Enamul
Has thanked: 271 times
Been thanked: 814 times
Re: SPI Slave
Post by Enamul »
I am not quite clear what you are looking for! You can easily use existing SPI to communicate data to&from slave SPI device just need to know some basic bits about the slave device..like address, clk transition,SPI clock polarity and supported speed.
Enamul
University of Nottingham
enamul4mm@gmail.com
Mathy
Re: SPI Slave
Post by Mathy »
Oh sorry, my english is still so bad :mrgreen:
I have already use the existing SPI macro to communicate with digital potentiometer for exemple. No problem for that.
But I would like to use SPI in slave mode to share data between two MCU or more so I need one MCU with a master SPI and some MCU with slave SPI.
Is it more clear ?
Enamul
Re: SPI Slave
Post by Enamul »
OK. Thanks. That's much clear now. If you don't need to strict to SPI you can use I2C to communicate between PIC. Here is a link for that where the code is mainly written for FCv4 but can be used for FCv5 with some correction for some of the chips.
http://www.matrixmultimedia.com/mmforum ... f=7&t=7081
Enamul
enamul4mm@gmail.com
