- the tmr2 macro increases a count everytime its accessed, the count starts at zero and counts up to 100, when count = 100 the count is returned to zero, what i did is turned the output on at count=0 and turned output off when the pwm variable = count,
this gives you a 0-100% dutycycle, all examples are running at 1000hz with 32Mhz osc but have different tmr2 frequencies
- in 1% resolution the frequency of the pwm is determined by tmr2 frequency / 100
- by modifying the tmr2 frequency you can hit many frequencys
- this makes it possible to use pwms on pins that do not have ccp so a board that doesn't give you access to the ccps pins thats not a problem when using something like this project
- you can use as many pwms as you want, and use any i/o pins you want
- in 1% fcf martins code ((adc*100)/255) rescales adc to 0-100, this goes directly to the pwm variable and you can print to the display those numbers as pwm% as its the same
- in other variations 2%,5%,10%,25% to print the number in the lcd macro i use code pwm* XX to put corrent number on display for pwm%
*** the pwm mentioned above and as in first fcf has a resolution of 1% per pwm increase, but you dont have to run 1% you can drop the resolution to anything you want by modifying this line of code in the tmr2 isr
if(count==100){count=0}1% --> 100
2% --> 50
5% --> 20
10% --> 10
25% --> 4
- all simplified flowcharts below have 1000hz as output frequency notice tmr2 settings are different
- for example if you want to set pwm frequency to 620hz with 5% resolution is 620*20= 12,400
use tmr2 calculator in seperate post (revised fcf) http://www.matrixmultimedia.com/mmforum ... 580#p42633 to find the settings for 12,400 hz, the closest frequency is 12,403 which has the prescaler,postscaler,rollover values of ( 1 - 15 - 43 ) @32Mhz osc , then since 5/100 is 20counts set your tmr2 macro decision to
if(count==20({count=0}Code: Select all
printNumber(pwm*5)-
