Measurement of temperature and relative humidity using DHT11
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Re: Measurement of temperature and relative humidity using D
I have got some requests to make the program in FCv4. But it's very time consuming as I have to re-write the whole code. I have taken screen shots of the whole code so that any one can write in FCv4 if they want. User can post after completing the code if that doesn't work. I can fine tune easily.
- DHT11.zip
- (2.57 MiB) Downloaded 932 times
Please have a little help.I have some questions.
Picture 8 - function calculation can not see everything.
Picture number 12 and 13 can not see everything.
Picture 7, C code... is so OK
st_bit(intcon, TMR0|E);
tmr0=0x00;
I would have to window variables.
Thank you.
rr
tmr0=0x00;
Thank you.
rr
- Enamul
Figure 8 calculation box..
After completing the code you can post..I will check that for you
RH_Byte1 = RH_Byte1 | (1 << (7 - i))I can't see any problem in picture 12 & 13Picture number 12 and 13 can not see everything.
That should be..st_bit(intcon, TMR0|E);
tmr0=0x00;
st_bit(intcon, TMR0IE);
tmr0=0x00;
Thanks for the information. I write code for AVR ATMEGA32.
I have a problem with sharing frequency. I can not share the frequency 20MHz clock with 1:4.
The figure below
What should I do?
One more question.
My mistake, picture number 12 and 13 is OK.
I have a question for Figure 10, calculation box. Missing C code.
Thank you very much.
rr
The figure below
What should I do?
One more question.
rr
- Prescaler_AVR.jpg (26.42 KiB) Viewed 28079 times
- Enamul
Ok..I see the TMR0 issue. I can sort that if you post the FCv4 AVR code when it is finished. I have to tune TMR0 initial value to make it working.
It is same as last c code I posted only RH_Byte2 is in place of RH_Byte1.One more question.My mistake, picture number 12 and 13 is OK.I have a question for Figure 10, calculation box. Missing C code.
RH_Byte2 = RH_Byte2 | (1 << (7 - i))Re: Measurement of temperature and relative humidity using D
Thank you for answer.
I attach the program for DHT11 Flowcode4 for AVR ATMEGA32. It is necessary to set TMR0.
Please see, if everything is OK.
RR
RR
- DHT11_in_DHT22_RR_konstrukcija_Matrixmultimedia.fcf_avr
- (21.05 KiB) Downloaded 819 times
- Enamul
I have to correct lots of things like right syntax for AVR register. Enable and disable code for TMR0. Need to select 1:64 pre-scalar for TMR0 which is initialized to 0xC0 to get right interrupt frequency..Now the code compiles fine. Can you please test that in hardware and let me know?
- DHT11_RR_konstrukcija_MM.fcf_avr
- (21.05 KiB) Downloaded 720 times
Hello Enamul.
Thank you very much for the optimization Flowcode4 AVR for DHT11. Sorry, but program does not work.
Using DHT22 sensor. DHT11 works the same as DHT22.
I think the problem in ATMEGA32. The maximum frequency is 16MHz for atmega32. On the atmega32 is necessary to reduce the frequency.
Enamul, how to calculate the value of TCNT0, if you have a quartz 11059200MHz? Is this a big problem?
We can a little help;).
Greetings.
RR
Greetings.
RR
- Enamul
I can explain you how I have calculated that for 20MHz. You can find your own.
For AVR, I think the instruction cycle 0.05 us. so the delay I am looking for using TMR0 is 204.8 us. so clock is defining pre-scaler..like 1:64 for me at 20MHz.
204.8/(0.05 * 64)=64..so 64 increment should cause overflow of TMR0. We know TMR0 overflows at 256..so 256-64=192 should be initial value at TMR0 register(TCNT0 in AVR). That's it. so you can choose your clock and right pre-scaler and right initial value.
Hello Enamul.
Thank you very much for the information. Very nicely explained.
I understand:
1/20000000Hz = 0,00000005s = 0,05us. One cycle takes 0,05us.
I do not understand: How to get value TMR0 is 204.8 us???
Can you explain that?
I understand:
Thanks.
RR
I understand:
I understand:
Thanks.
RR
- Enamul
I am confused..did you mean you understand my explanation or not?I understand:
Sorry for the bad question.
I do not understand how to calculate the value TMR0 is 204.8 us.
204.8 us how to get this value?
Thanks.
RR
Thanks.
RR
- Enamul
You can follow this link..I have explained there
http://www.matrixmultimedia.com/mmforum ... 46&t=11641
- Enamul
Yes, you can show the value in 7-segment LED and u don't need to make to BCD just need to separate the digits to display in 7 segment. Flowcode can easily help you to display those in 7 segment.
Thanks Enamul
but in this case every number required 7 pins from the pic ,
so if i want to show temperature , humidity in the same time
using a 16f or 18f family pic I can't do that
that's why i'am looking how to change to bcd
I found this thread http://www.matrixmultimedia.com/mmforum ... 20&p=18900
and I'am trying
and I'am trying
- Enamul
In multiplexed display you will need 8 pin for a,b,c..g and dp and common cathode or anode will be driven by one pin for each 7 seg Led. So you need maximum 4 pin + 8 pin
It's me again
Compiled program for reading DHT11, but does not work. I used atmega32 and 10MHz Quartz. I changed the value of TCNT0 = 0xE0. Prescaler 1:64. The program is written in Flowcode4
DHT11 sensor is purchased http://www.ebay.com/itm/370691456827?ss ... 1497.l2649
Or you can check program? What I do wrong? I would be very happy.
Thanks!
Rradojko
It's me again
Thanks!
Rradojko
- DHT11_RR_konstrukcija_Matrixmultimedia_BY_Enamul.fcf_avr
- (22.6 KiB) Downloaded 674 times
- JohnCrow
- Has thanked: 364 times
- Been thanked: 716 times
DHT11 With Alarm Outputs
I have made a small addition to Enamuls code to add over/under alarms to both the temperature and humidiy readings.
The display shows
Temp = TL TH OK
Humidity = HL HH OK
Ive built a small pcb with RGB LEDS. (One for temperature and one for humidity)
Red = Over
Green = OK
Blue = Under
The setpoints are changed by editing the values in the flowcode variables
Temp_Low = 16
Temp_High = 24
Humidity_Low = 40
Humidity_High = 60
This program only compares with the integer part of the measured value. I considered this would have enough accuracy considering the overall accuracy of the sensor.
The display shows
Temp = TL TH OK
Humidity = HL HH OK
Red = Over
Green = OK
Blue = Under
Temp_Low = 16
Temp_High = 24
Humidity_Low = 40
Humidity_High = 60
Hello,belayat wrote:Hello enamul sir
could you please write the algorithm of the program "DHT11v1.01.fcf" for the beginners.
belayat
I agree. This would be good for beginners. My algorithm still does not work.
I would ask for an explanation DHT11.
RR
- Enamul
Sean Danaher
- Has thanked: 3 times
- Been thanked: 1 time
I also use the DHT11 but with a PIC 12F683 acting as a 1-wire slave emulator and a 1-wire master (PIC Arduino or commercial) to display the data. I find that the ability to emulate 1-wire slaves (mainly DS18B20s), is very useful.
Happy to post more details if anyone is intereted
Sean
Sean
hello enamul,
I need your help, your program for the anemometer you set the pulse as follows:
1 pulse /1 second = wind speed 0.1 m / s.
but I will: 1 pulse / 2.25 seconde = wind speed 1 mph (0.44 m / s)
