lcd screen flicker
siliconchip
- Has thanked: 101 times
- Been thanked: 25 times
lcd screen flicker
hi all i have created a flowchart using pwm initially to gain some understanding of it the problem is although it simulates in flowcode as i intended, on actual hardware the screen flickers,i have tried to eliminate this using different clock speeds as well as increasing a delay value but i am no closer to solving it, can anyone point me in the right direction please
- MY PWM.fcf
- (11.5 KiB) Downloaded 334 times
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Re: lcd screen flicker
Can you please try this one?
Edit: I have deleted the clear display function in the loop and increased delay to 250ms. Added two space after "%" so that it is now "% " in the code which removes any unwanted character if 100% to 99% or 10% to 9%.
- MY PWM.fcf
- should be Fcv4 but can't open yours one in FCv4 that's why in FCv5
- (11 KiB) Downloaded 386 times
siliconchip
thanks it works brilliantly obviously the lcd clear was not needed thanks once again
