Apple Remote Control *Working Program*
hyperion007
Has thanked: 49 times
Been thanked: 101 times
Post by hyperion007 »
Has anyone used a Apple remote control, the aluminum one for example, with Flowcode? I know how to use the RC5 module in FC but as the Apple remote uses a apple version of the NEC protocol, I don't know how to get this working. I would love to be able to use this remote control as it is very nice.
Any help would be great. I found this page: http://hifiduino.wordpress.com/apple-aluminum-remote/
I don't even know what kind of IR receiver I should get.
/Daniel
Enamul
Has thanked: 271 times
Been thanked: 814 times
Re: Apple Remote Control?
Post by Enamul »
Enamul
University of Nottingham
enamul4mm@gmail.com
hyperion007
Thanks for your reply.
I have found what IR sensor I should use and have gotten one, so I will be experimenting with this as soon as I get my hands on a remote :)
The unilink doesn't work for me though, if you by any chance saved it, could you attach it here?
I'll keep updating this thread as I get on with this project.
Thanks.
hyperion007
Ok, I have everything connected
I am using a PIC18F2520 and have the output pin from the ID receiver (TSOP34838) connected to RC7
But now I am stomped. I don't know what to do to be able to read the codes that the remote is sending. The carrier frequency is 38Khz and I can see that the receiver is working by connecting a LED on the output and pressing a button on the remote, the LED starts to flicker ever so slightly.
The codes that the remote is sending are:
2011242643 - Play/Pause
2011287699 - Volume Up '+'
2011279507 - Volume Down '-'
2011238547 - Previous
2011291795 - Next
2011250835 - 'Menu'
I have made a macro that is called over and over from the main loop
It is not as simple as to just listening to the input of RC7 and returning its value to a variable that is Long number
I gather that I probably need to use some sort of timer or interrupt but I don't know how.
Anyone knows?
hyperion007
This can now be moved to the V5 forum (I have registered for the V5 portion of the forum)
hyperion007
I think the addition of a Apple remote component to use with FC would be great for anyone wanting a simple yet elegant remote control that is also readily available.
It seems very popular with the Arduino crowd.
Sparkoids
Has thanked: 30 times
Been thanked: 19 times
Post by Sparkoids »
I have the original white remote control from Apple which uses the same keys and agree this is a good idea...
hyperion007
I have a white one as well for testing but placed an order for two aluminum ones today.
Do you have any idea on how to make this work? :)
hyperion007
I have now been able to get TMR0 and INT2 working so that I get a reaction when I press the remote control.
But I cannot seem to get the correct "timing" so that I can determine if there is a zero or a one.
The codes that I posted earlier are 32bit
The timings of the remote control are:
Protocol on (µs) off (µs) total (µs)
leader 9000 4500 13500
0 bit 560 560 1120
1 bit 560 1690 2250
stop 560 N/A 560
I have tried many different prescaler settings on the timer and calculated different Pulsewidth values but the closes I came was a RCpacket01 value of 21845 which is 0101010101010101
PIC18F2520_temp.fcf
(51.13 KiB) Downloaded 302 times
hyperion007
I have had some luck with reading out the header.
I think I only need to know the off pulse-width to know if it is a 0 or 1
Also, I only need the third Byte and really only the first 7 bits of it. And the remote sends each byte (4 Bytes in total per button) with LSB
I don't seem to be able to capture all pulses.
I get 175 ticks when testing only the header's off pulse every time I press a button on the remote so that seems accurate, but after that everything goes sour :(
Look at the macro "RC" in this FCF file please and try to figure out what I am doing wrong here.
Feel free to make a new variable to store the captured Byte 3 with LSB first.
If my calculations are correct then:
4500us which is the header off time equals the 175 ticks I have been getting from TMR0 with prescaler 1:128
Then a "0" which has a off time of 560us would equal 20-25 ticks of TMR0
And a "1" with a off time of 1690us would equal 60-70 ticks of TMR0
Thanks for any and all help on this.
PIC18F2520_temp.fcf
(77.22 KiB) Downloaded 296 times
hyperion007
Ok,
I have re-written this program, for the PIC18F4550 and only included the RC portion of the program
Maybe now someone wants to have a look at it?
Right now I am getting 0x55 or 01010101 or decimal 85 from the first 8 bits and then I turn the RB2INT off,
I should be getting 0xEE or 11101110 or decimal 238 but that is not the case :(
Please help me with this.
PIC18F4550_Apple_RC.fcf
(17.22 KiB) Downloaded 257 times
hyperion007
I am now left with two problems
1. I need to change the order from LSB to MSB on all four bytes
2. I get correct data from the remote on the first button I press after I restart the PIC (but in LSB format instead of MSB). But when I press the next button, the information in all 4 bytes are wrong
On first button press I get:
Byte1: 119 (0111 0111) it should be (1110 1110)
Byte2: 225 (1110 0001) it should be (1000 0111)
Byte3: 160 (1010 0000) it should be (0000 0101)
Byte4: 208 (1101 0000) it should be (0000 1011)
but when I press the same button again, or another button, nothing makes sense.
I should be getting:
Byte1: 119
Byte2: 225
Byte3: should change if another button is pressed
Byte4: 208
(20.81 KiB) Downloaded 224 times
hyperion007
Never mind, I got it working. I don't need to convert from LSB to MSB
If anyone want to use an Apple remote they can use this.
Byte3 is the command byte
Here are the codes with my program:
So IF RCbyte3=
Play/Pause: 160
Vol-: 48
Vol+:80
Next:96
Prev:144
Menu: 192
(26.87 KiB) Downloaded 236 times
