Can't get RS232 to simulate or work in hardware
markus747
Has thanked: 26 times
Been thanked: 2 times
Post by markus747 »
The macro which reads rs-232 is set to interrupt 244 times a second to read 1 byte each pass
I put bytes 170,12,125,either in same file or using Vnet to send data and it never gets read in from rs232.
Can't figure out how to get reliable data at 9600 baud
I assume flowcode is storing more than the 2 bytes the buffer will hold (is this true?)
if so how many?
Any help greatly appreciated
TIA
RS232 OUT.fcf
(9 KiB) Downloaded 306 times
18F43K22 16.32_92.fcf
(67.61 KiB) Downloaded 266 times
Enamul
Has thanked: 271 times
Been thanked: 814 times
Re: Can't get RS232 to simulate or work in hardware
Post by Enamul »
You have had a problem in your RS232 receive macro. I have shown the right format of receiving macro in the snap-shot. you put variable in the nTime place but it should be in return data place. nTime could be 1 if you use interrupt for detecting RS232 reception but if the wire length is loo long you can wait up to 5 to maintain reliability. I have seen in my one project 5 is pretty enough for few meter distance with INT. BTW I have corrected code. Please let me know how it's behaving now.
(67.62 KiB) Downloaded 280 times
(37.75 KiB) Downloaded 1938 times
Enamul
University of Nottingham
enamul4mm@gmail.com
markus747
Post by markus747 »
not working yet
also changed interrupt to be slower but still no RS232 data being received into variables
Enamul
Post by Enamul »
I would suggest you to make the receiving code simple for the time being to simply test different the RS232 transmission and reception. You can post simple Tx and Rx program. I will have a look if there are any issue still left.
Enamul
enamul4mm@gmail.com
markus747
Post by markus747 »
Ok now I got it to work with VNET and it simulates! :) :)
but doesn't work in hardware!
I had to put macro call in main loop instead of interrupt driven (takes forever to simulate with TMR0 divider set to 256)
But even when compiled same as simulation still no response from serial data.(From Hardware)
PS2 SERIAL OUT.fcf
(16.5 KiB) Downloaded 278 times
18F43K22 16.32_93.fcf
(66.02 KiB) Downloaded 276 times
Enamul
Post by Enamul »
I have noticed couple of issues in the code. I will correct those and post asap. I haven't check your Rx code earlier in details...but checked just now. I have requested you to post simple Rx program not the whole code. It's not easy to debug where the problem is. I can't even find where you are calling RS232 macro( I mean I might have missed that in the long code). Please post a small example so that I can check that easily and you can then add the changed bit in your final code. I would suggest to RXINT for RS232 receive otherwise you will not get reliable behavior.
Enamul
enamul4mm@gmail.com
