CCP8 Why can't compile HEX file in dspic33FJ32MC204!
nnnnff
Has thanked: 3 times
Been thanked: 6 times
Post by nnnnff »
CCP8 Why can't compile HEX file in dspic33FJ32MC204!Please help me.
Flowcode1.fcf_pic16
(8 KiB) Downloaded 248 times
Re: CCP8 Why can't compile HEX file in dspic33FJ32MC204!
From the datasheet there are only two standard PWM channels on this device not eight. I will update the FCD file so that it reduces the available count from 8 to 2.
Compiling with any channel set other then 1 or 2 causes the same compilation errors because the required CCP (capture compare) registers are not there on the device.
Would software PWM based on a timer interrupt be any good to you?
