Flowcode 4.2.3.58 INT pin 12F683 (still) not working
yfands
Flowcode V4 User
Has thanked: 3 times
Post by yfands »
I have some smaller projects and would like to use the 12F683 with INTerrupt possibilities,
I have the same problem(s) as stated in 2009 with Flowcode 3. My version is Flowcode V4 en is (still) showing me the RB0INT lables
instead of GP, And I cant get the INT pin, or as a matter of fact using the complete PORT as INT, to work. I tried several other 12F683.fcd files
(V3 V5) but they claim to be corrupt, could be right I;m using V4, but also the found V4 versions do not work (still have references in there content to RB0 etc,)
I like it labelled by there right names for adminstrations sake.
Where can I find the right 12F683.fcd file for V4?
btw I have the same issue with the 12F675
Regards Frank
dazz
Has thanked: 474 times
Been thanked: 458 times
Re: Flowcode 4.2.3.58 INT pin 12F683 (still) not working
Post by dazz »
try this post
http://www.matrixmultimedia.com/mmforum ... %A6#p35013
remember to back up files before changing them
Dazz
Enamul
Has thanked: 271 times
Been thanked: 814 times
Post by Enamul »
I think you are using old version of Flowcode v4 as you are using V4.2 whereas V4.5 is the latest version. Can you please try to update your version and see the issue again?
Enamul
University of Nottingham
enamul4mm@gmail.com
I believe what Frank is asking for is if the labels within the rings can be changed from RB0INT to GP2INT
(14.34 KiB) Downloaded 4298 times
To:
(17.69 KiB) Downloaded 4288 times
I have used latest version of Flowcode V4 and can confirm INT of 12f683 does work, but there is an issue with IOC which I corrected and dazz kindly placed a link to it.
You state in your title 'Flowcode 4.2.3.58 INT pin 12F683 (still) not working'
I totally agree what Enamul has stated. You should be using the latest version which is Flowcode v4.5.18.74
Either use Help menu and check for updates, or make sure you have your key as you will need to enter the last two sections of your license key including the dash here:
http://www.matrixmultimedia.com/flowcode.php
Just scroll down the page a bit.
If your trying to update an oldr version of Flowcode with FCD file created for the latest problem, you will have a corruption waening, and would not be able to open a flowchart for that specific target device.
Enamul
Post by Enamul »
If that is RB0INT to GP2INT change, it can be done by FCD. I have done that earlier. Frank please confirm that if you want I can do that for you
Enamul
enamul4mm@gmail.com
Enamul
Post by Enamul »
Here is FCD with GP2INT
12F683.fcd
(6.73 KiB) Downloaded 378 times
Enamul
enamul4mm@gmail.com
Thanks for modified FCD file Enamul.
I have a modified FCD file that also includes Timer1 and Timer2 interrupts as well and removed IOC bug when you select off for IOC options, then IOC will not work.
Attached are two files one for 12F693 and other is for 12F617
If you back up and replace your current 12F683.fcd located in your Program files\Matrix Multimedia\Flowcode V4\FCD folder if 32 bit windows
or
Program files (x86)\Matrix Multimedia\Flowcode V4\FCD folder if 64 bit windows
12F617.fcd
(10.47 KiB) Downloaded 363 times
12F683.fcd
(10.35 KiB) Downloaded 347 times
yfands
Flowcode V4 User
Post by yfands »
and thanks for your replies..
Here are my findings on your suggestions:
[dazz] The IOC port change didn't make a differnce, couldn't get the INT to work.
[enamul] To update to the latest version is always a good idea, but I was confinced that it must be working with the older version and a good 12f683.fcd file.
[medelec35] thanks for the clarification about the (ring)labels, it was a double question a) not working b) the right labels.
[enamul & medelec35] thanks for the modified 12f683.fcd file all is working now (with the old V4 version)
Till I updated to version 4.5, This version is setting me back with an old/not updated version of 12f683.fcd..., yes indead the one with the RB0 labels and not working
guys at Matrix, really !!!!!!
So I had to put back the file from [enamul & medelec35] and also with 4.5V all is working.
Regards and thanks for your input,
Frank
Enamul
Post by Enamul »
Thanks for letting us know by an organised post :)
Enamul
enamul4mm@gmail.com
