MIAC Stepper Motor Speed Control
Chris_MIRA
Has thanked: 2 times
Been thanked: 21 times
Post by Chris_MIRA »
Im using a MIAC to directly drive a stepper motor, everything works well in simulation and I can control the speed by varieing the delay between steps. However when running the programm on the MIAC, the speed is constant (and slow) regardles of the delay time. Any ideas? Help much apresiated! Is there a "Speed Setting" on the MIAC or stepper MACRO that Im missing?
Chris
Re: MIAC Stepper Motor Speed Control
Hi Chris,
The problem is likely to be inside your program. Could you attach it so we can have a look.
You can PM me with it if the program is commercially sensitive.
Chris_MIRA
Please find the code file attached. As I said in the original post, the speed variation is fine in simulation but not on the real MIAC hardware. Any help / advice welcome!
Chris
BEST Revolver stuff.fcf
(17.81 KiB) Downloaded 386 times
Chris_MIRA
Hi, any further thoughts on the code I attached? I still cant get a faster speed on the motor.
Chris
Hi Chris,
All the delays and LCD commands will be consuming processor run time which means that the delays in between steps may be a bit longer then you are expecting.
One way would be to enable the motor and then configure a timer interrupt to run. Varying the speed of the interrupt will vary the speed of the motor and disabling the timer interrupt will stop the motor. Remember to disable the motor if it is stopped for periods of time or you risk burning our the motor coils.
