which I don't know how to avoid.Serious Warning: Possible sw stack corruption, function 'delay_us' called by more than one asynchronous thread (main/Task, interrupt, interrupt low)
Due to IP concerns I cannot attach the whole program anymore, but here is the routine that I suspect falls over with and without the var:
MX_UINT8 FCM_Hex2Int(MX_CHAR* PFCL_HEX2_INT_STR)
//Local variable definitions
MX_UINT8 FCL_LENGTH;
MX_UINT8 FCL_COUNT = (0x0);
MX_UINT8 FCL_INT_VALUE = (0x0);
MX_UINT8 FCL_INT_CONVERSION = (0x0);
MX_UINT8 FCL_INT_VAR = (0x0);
MX_UINT8 FCL_INDEX = (0x0);
#define FC_SZ_HEX2_INT_STR 20
MX_UINT8 FCL_HEX2_INT_STR[FC_SZ_HEX2_INT_STR];
FCI_CONCATENATE(PFCL_HEX2_INT_STR,FC_SZ_HEX2_INT_STR,"",0,FCL_HEX2_INT_STR,FC_SZ_HEX2_INT_STR);
MX_UINT8 FCR_RETVAL;
//String Manipulation
//Calculation:
// .length = Length$ (.hex2_int_str)
FCL_LENGTH = FCI_GETLENGTH(FCL_HEX2_INT_STR, FC_SZ_HEX2_INT_STR);
//Calculation
//Calculation:
// .count = 0
// .int_value = 0
// .int_conversion = 0
FCL_COUNT = 0;
FCL_INT_VALUE = 0;
FCL_INT_CONVERSION = 0;
//Loop
//Loop: While .count < .length
while (1)
//Calculation
//Calculation:
// .int_var = (.length - .count) - 1
FCL_INT_VAR = (FCL_LENGTH - FCL_COUNT) - 1;
//Calculation
//Calculation:
// .index = (.length - .count) - 1
// .int_var = .hex2_int_str[.index]
FCL_INDEX = (FCL_LENGTH - FCL_COUNT) - 1;
FCL_INT_VAR = FCL_HEX2_INT_STR[FCL_INDEX];
//Decision
//Decision: .int_var > 64?
if (FCL_INT_VAR > 64)
//Calculation
//Calculation:
// .int_var = .int_var - 55
FCL_INT_VAR = FCL_INT_VAR - 55;
} else {
//Calculation
//Calculation:
// .int_var = .int_var - 48
FCL_INT_VAR = FCL_INT_VAR - 48;
//Calculation
//Calculation:
// .int_value = .int_var << .count * 4
// .int_conversion = .int_conversion + .int_value
FCL_INT_VALUE = FCL_INT_VAR << FCL_COUNT * 4;
FCL_INT_CONVERSION = FCL_INT_CONVERSION + FCL_INT_VALUE;
//Calculation
//Calculation:
// .count = .count + 1
FCL_COUNT = FCL_COUNT + 1;
if ((FCL_COUNT < FCL_LENGTH) == 0) break;
//Calculation
//Calculation:
// .Return = .int_conversion
FCR_RETVAL = FCL_INT_CONVERSION;
return (FCR_RETVAL);
#undef FC_SZ_HEX2_INT_STR
TIA
