delay function does not work. FC5
rene
Has thanked: 5 times
Been thanked: 2 times
Post by rene »
Hi Boys en Girls....
I make use the 16F628A. and it seems that with FC5 the delay's not work anymore ...
I have a serious time problem :(
oscillator set to: INTOSC I/O
Clock Speed ​​4000000 hz selected ..
as additional setting in C at the start of program >>>> set_bit (pcon, 3)
To force the 4MHz clock, But should not be necessary.
someone with sugestions?
Thanks....
René
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: delay function does not work. FC5
Post by kersing »
Adding a simple flowchart that shows the problem helps... It allows those trying to answer the question to take a look at your code, verify the settings are right and (if we own that particular chip) even try it.
― C.S. Lewis
