MCP3208
Jordy101091
Has thanked: 25 times
Been thanked: 188 times
MCP3208
Post by Jordy101091 »
HI everyone,
For A project im trying to interface a 8CH 12Bit ADC "MCP3208", Im tryin all day to get it to work but I not getting anything out.
I hop somebody can help with this as I don't know what i'm doing wrong.
I have checked all my signals and I'm 99% sure that they are connected correctly.
Datasheet of: MCP3208 http://ww1.microchip.com/downloads/en/d ... 21298c.pdf
I have attached my Flowcode below
Regards Jordy
Controller.fcf
(40.31 KiB) Downloaded 178 times
Jordy101091
Re: MCP3208
Hi all,
Does nobody have an idea what I'm doing wrong here.
Regards Jordy
Re: MCP3208
Hi Jordy,
Is the D1 signal your Chip select signal?
If so then it looks like your almost doing things correctly. The last send char 0b00000000 is probably not required as the transaction is completed after 3 bytes.
Looks like the sending begins halfway through the second byte which is helpful.
Here is an example which should collect the lower 8-bits of the result. If you also need the upper 4 bits then let me know and I will see what is possible.
Controller.fcf
(40.04 KiB) Downloaded 182 times
