(Sorry for the bad english)
I used to work on the pic 16F877A and everything worked. But there wasn't enough space so i chose the 18F4520 to work with because it has more space and basically the same pins.
My project need a SD card, a GPS, a gLCD, but i had issues about the SD card. So i upgraded the version to 5.5.2.1 and now the SD card work BUT the gLCD doesn't.
So the real problem now is that the gLCD (EB076, we only have this one, the others are down) print the message "4D Systems bla bla bla" and nothing about our program. I took the test program of matrix multimedia and nothing happened. I tested on the 16f877a with the lastest version and it works. But not on the 18F4520. So anyone knows how to program a gLCD on this PIC? Or knows a PIC similary which can be programmed like the 16f877a and has a great memory ?
Thank you for the help.
