Semiconductor Temperature Sensors
- JohnCrow
- Has thanked: 364 times
- Been thanked: 716 times
I have, over the last couple of years experimented with several different types of solid stare temperature sensor devices.
These mostly have a direct mV/°C output.
The biggest problem with most of them is they don't measure negative temperatures, exceptions to this are normally more complex to use.
The DS18S20 can read negative but uses the 1 wire bus. While supported in FC it is not as easy to use as the above type.
The LM335Z can read negative but its output is mV/K (Kelvin).
This needs an extra line of calculation to convert back to °C, and the hardware needs a trimmer and pull up resistor to set the optimum accuracy.
The TMP102 has a good accuracy but uses the I2C bus. This can make programming tricky for the inexperienced
I've recently tried the TMP36 device.
This again has a 10mV/°C but reads from -40° to +125°C (Data sheet figures).
It can run with a supply of 2.7 V to 5.5 V and has a worst case accuracy of 2°C (1°C around 25°C), which make using it with ARM devices as simple as PICs and AVRs.
No extra hardware is needed, just a simple 3 wire connection.
Pin1 = Vcc
Pin2 = Out
Pin3 = Gnd
The device is ideal as the basis of a wide range thermometer.
Ive attached a simple example flowchart below.
Pin1 = Vcc
Pin2 = Out
Pin3 = Gnd
Steve001
- Has thanked: 460 times
- Been thanked: 523 times
Re: Semiconductor Temperature Sensors
[quote="JohnCrow"]I have, over the last couple of years experimented with several different types of solid stare temperature sensor devices.
Hi john i know that you like playing with temperature sensors have you seen the devices on analouge devices site ? if you create a id they can send you FOC samples
i have obtained a few devices this way .
http://www.analog.com/en/analog-to-digi ... re_Sensors
above is the selector
spark fun do a SOT23 to DIP convertor pcb
http://proto-pic.co.uk/sot23-to-dip-ada ... tAodgwsAmA
registration page
https://registration.analog.com/Registr ... ?locale=en
registration page
- JohnCrow
Hi Steve
Thanks for the links, I keep intending to try and get a few samples from various places.
Ive used the sparkfun breakout boards for SMD to dip, they are useful devices.(Not tried that one though)
Steve001
there is this little beauty just had to go and dig it out of my components box a tad expensive i know
not had chance to play with it yet tho
http://uk.farnell.com/jsp/displayProduc ... tch|p|plid|
it interfaces various thermocouples to a 10mv/c signal this one is type K (−200 °C to +1350 °C)
steve
steve
- JohnCrow
Hmm
I used them (or maybe a similar device) for a project when I was at college (paid for by work so cost didnt matter).
They worked very well.
Just used a DVM module to show the temperatures.
jgu1
- Has thanked: 1135 times
- Been thanked: 299 times
Hi John/all!
I also made a program with a TPM36. I would use it for a thermostat.
You can adjust its nominal temperature by pressing Set then the up / down. If you press Set again, you can adjust the hysteresis of temperature upwards. press again Seen and you can adjust the hysteresis down. Press Set again and the thermostat will turn on and off the set formulas. The accuracy is only in whole degrees. The program stores the adjustments in EEPROM, so a power failure retrieves the data again. There is certainly something that can be improved, but it works fine by me. Maybe useful
Best regard
Jorgen
Best regard
Jorgen
- TermostatMakroInterrupt.fcf
- (59.7 KiB) Downloaded 544 times
Kenrix2
- Flowcode v5 User
- Has thanked: 72 times
- Been thanked: 177 times
Some Pic micros have a temperature unit. I have used them in the past for various monitoring uses but not for getting the the exact degree centigrade.
Here is a sample. It is made with V4.5 ,however, it should work with V5.
- Internal_Temperature.fcf
- (8 KiB) Downloaded 540 times
- JohnCrow
Hi Kenrix
Thats a very interesting idea, just tried it with the 16F1827 and FC5
It seems to work as you say. Gave the PIC a spray with an inverted air duster, and cooled it down and the display shows about 160.
Room temp is about 24°C and its showing 210.
As you say not highly accurate, but it could certainly be useful.
Thanks for the info.
Here is my two pence worth.
How about this:
http://uk.farnell.com/jsp/search/produc ... ku=1439483
Price from Farnell:
Since Output Voltage per °C: 19.5mV/°C ( 5/256=19.53mV)
That makes flowcharts very easy to create.
So bytes increase/decrease by 1 every deg C
Also no additional components are required.
How about this:
THERMISTOR, LINEAR 19.53MV/C, TO-92
IC Output Type: Voltage
Sensing Accuracy Range: ± 2°C
Sensing Temperature Min: -40°C
Sensing Temperature Max: +125°C
Supply Voltage Min: 3.1V
Supply Voltage Max: 5.5V
Sensor Case Style: TO-92
No. of Pins: 3
Resolution (Bits): 8bit
Supply Current: 6µA
SVHC: No SVHC (19-Dec-2012)
Base Number: 9701
Operating Temperature Max: 125°C
Operating Temperature Min: -40°C
Operating Temperature Range: -40°C to +125°C
Output Current: 100µA
Output Voltage: 400mV
Package / Case: TO-92
Resolution: 8bit
Sensor / Transducer Type: Temperature
Supply Voltage Range: 3.1V to 5.5V
Temperature Sensing Range: -40°C to +125°C
Termination Type: Through HoleCode: Select all
Qty List Price
1 - 9 £0.24
10 - 99 £0.159
100+ £0.133
