Converting EB005 display control to I2C
Brendan
Has thanked: 140 times
Been thanked: 118 times
Post by Brendan »
I've been struggling trying to get an I2C interfaced display working (posted elsewhere), as I'm clearly missing something in the LCD driver datasheet. This is for a PIC-based test jig where the display is interfaced via I2C.
Looking at an alternative route, the on-board display driver chip (Sitronix ST7032i) is evidently code-compatible with the HD44780 that I understand is used on the E-Blocks EB005.
I would therefore like to edit the code / Flowcode (V5) to make use of the provided EB005 display driver functions, but converting the parallel (4-bit) output to suit the preordained 8-bit I2C of the tested product. If relatively straightforward I'd be extremely grateful for guidance.
Many thanks in advance.
Brendan.
Re: Converting EB005 display control to I2C
Hi Brendan.
Programming Tips & Tricks is not for questions or technical support.
It's only for people who are posting tips,tricks and sharing their working Flowcharts.
So I have moved your post to a more relevant part of the forums.
Brendan
Post by Brendan »
Oops... My bad, and apology :oops:
Thanks Martin :)
All the best,
Brendan
Brendan
Post by Brendan »
My original issue has now been resolved and the I2C display now working in native Flowcode (after a critical header byte value was corrected :roll: )
My particular thanks to Jac (Kersing) for taking the time to dig out and PM some well-written example 'C' code :D
All the best,
Brendan
bercioiu
Has thanked: 90 times
Been thanked: 34 times
Post by bercioiu »
interesting!
Can you share with us the hardware and flowcode settings? I'm looking for something like that for a long time.
Thanks!
Brendan
Post by Brendan »
Sorry for the (very) late reply.
Here's the code that worked to produce just a one-liner in the LCD (which was enough for the test exercise).
Not entirely clean and slick, but got the job done and off my back :D
All the best,
Brendan
I2C_Display_Test_WORKING_23-Jun-2013_VerE.fcf
(43.72 KiB) Downloaded 358 times
bercioiu
Post by bercioiu »
It is not so late, it's only one day after a month :-)
Thank you for your reply, I thought you made a custom code for the LCD and we can use LCD natively in Flowcode ...
Any way, thank you again!
